Lowered ISF
Old 01-23-18, 09:36 AM
Stingraygt
Stingraygt's Avatar
Are you vehicles stock ride height or lowered? I have the swift springs and dropped 1" in the front and 0.6" in the rear.
Old 01-23-18, 06:41 PM
Weapon F
Weapon F's Avatar
I have Figs front LCA bushings in both pivots. Yes, they occasionally make some noises especially in the cold. They have eliminated inner edge wear even toed out 0.04 degrees on both sides. I plan to replace the rear LCA polyurethane bushings with the bearings and put the poly bushes on the GS F. I have the 90 durometer units and I did not notice an increase in NVH when I installed them, but I did a number of things all at once (Giken diff spool and diff bushings) so everything was a little different once it got back on the ground.
I have no reason to believe the USRS would be any different. I chose Figs because I wanted both LCA bushings replaced, not just the rear bushing.
I have recently changed some suspension components utilizing some figs components along with Bilstein B6 shocks superpro polyurethane bushings Swift Springs sikky sway bar few other odds and ends
Lowered ISF-20171117_180531-1024x1820.jpgLowered ISF-20171117_180440-1024x1820.jpgLowered ISF-20171110_134252-1024x1820.jpg
Old 01-23-18, 06:44 PM
Weapon F
Weapon F's Avatar
Super pro bushing
Lowered ISF-20171117_172749-1024x1820.jpgLowered ISF-20171117_144908-1024x1820.jpgLowered ISF-20171117_164435-1024x1820.jpgLowered ISF-20171117_171333-1024x1820.jpg
Old 01-23-18, 07:17 PM
Weapon F
Weapon F's Avatar
Front upper inner control arm offset poly bushing kit.
Lowered ISF-20171110_135907-1024x1820.jpgLowered ISF-20171110_135946-1024x1820.jpgLowered ISF-20171110_135953-1024x1820.jpgLowered ISF-screenshot_20180123-215436-1440x2560.png
Old 01-23-18, 07:29 PM
Weapon F
Weapon F's Avatar
Figs front endlinks, Sikky sway bar and endlinks etc
Lowered ISF-20171110_134248-1024x1820.jpgLowered ISF-20171117_200833-1024x1820.jpgLowered ISF-20171117_182146-1820x1024.jpgLowered ISF-20171117_193018-1820x1024.jpgLowered ISF-20171110_132408-1024x1820.jpgLowered ISF-20171117_193022-1820x1024.jpgLowered ISF-20171110_204158-1024x1593.jpg
Old 01-24-18, 08:51 AM
Stingraygt
Stingraygt's Avatar
Good feedback. Thanks
zen
IS F (2008-2014)
37
02-25-21 06:32 PM
sparkyguy
Suspension and Brakes
06-07-18 11:39 AM
DrBrown54
SC- 1st Gen (1992-2000)
09-01-15 01:39 PM
Five1OH
02-22-09 08:09 PM
SuperCoupe400
06-02-07 06:42 AM
Quick Reply: Lowered ISF
