Engine Error Codes
Tech Info Resource
O2 sensor problems. Could be lots of minor things.
Reset it came back on. I blended some e85 into my tank a couple days before this happened. I’ve done it a few other times and been fine. You think that’s what set it off?
Tech Info Resource
So you had a 27% ethanol blend total (assuming 10% ethanol in the remainder of the fuel you put in)?
Tech Info Resource
You realize the seals in the fuel system are not rated for more than 15% alcohol?
stasek
02-02-18 08:50 AM
