Figs or RR Racing LCA bushing?
Old 02-04-18, 01:34 PM
highrev6
highrev6's Avatar
Originally Posted by flowrider
^^^^As I indicated above they do effect NVH, so yes you will feel more of the road. Of course no effect shock on damping. One other advantage no one has mentioned is much reduced brake dive. On my ISF, brake dive has all but been eliminated. IMHO, wheel integrity will not be comprised by stiffer bushings.
Lou
well im going to have to order a pair and try them out. Worst case scenario I don’t like the changes and I switch back to the normal stock ones.
Old 02-04-18, 01:52 PM
Rossi
Rossi's Avatar
I have Figs 90 bushings, I believe that is the only kind they currently produce, I believe the softer version went away after the first run. Anyway, inner tire wear was addressed, steering is sharper, zero impact on the ride quality. I had these for 30k miles. Highly recommend. Back when I got them, I even got some money back with core exchange.
Old 02-04-18, 02:20 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,016 Likes on 2,432 Posts
Better than all of this, braking near the limit is much improved and the wander the car had before is gone. I have noticed no difference at all in NVH and I replaced all four LCA bushings on the front of my car with Figs 90 durometer bushings.
The OEM suspension isn't even close to "track ready" because the front toes out dramatically under heavy braking. This makes the car feel like it is wandering (or the F/R brake bias is really bad) and reduces front traction while you are slowing from high speeds approaching a low speed corner. It also causes accelerated inside edge wear on the front tires. If you look at the video Figs posted here, it's really obvious the OEM bushing was intended to reduce NVH and nothing more. It couldn't be further from track ready.
All that said, if you trail brake heavily, you might like the bushing from the factory. It does help turn in even if it does compromise braking.
Old 02-04-18, 02:33 PM
flowrider
flowrider's Avatar
Received 1,926 Likes on 1,358 Posts
Not according to the web site:
http://www.shopfigs.com/v3/CAT-LEXUS...P3491K-IN-BRKT
Lou
Old 02-05-18, 06:49 AM
NSXGuy
NSXGuy's Avatar
I have the Figs bushing. Great mod. I'm at 29k miles on the front tires and can see them lasting another 5k-10k miles. Absolutely worth it. I don't notice much if any NVH in the ride. Even if I did, it would be worth it to double the life of the front tires.
Old 02-05-18, 07:32 PM
Tom2769
Tom2769's Avatar
I installed the RR USRS shortly after buying my car and the added NVH was just a bit more than I cared for. I switched to Figs 90 durometer and couldn't be happier. The Figs are a little more progressive than the RR. The Figs gives you almost all the precision of the RR without some of the added NVH. Perfect compromise for me.
The following 5 users liked this post by Tom2769:
greys0uled (09-28-22), Hamed1 (07-01-20), henry1229 (06-01-18), nigel821 (04-19-21), Ramfis (02-05-18)
Old 02-05-18, 09:09 PM
Vitveet
Vitveet's Avatar
Ah! That post should end the thread! Someone with personal experience with both products in question!
V.
Old 02-05-18, 09:25 PM
Ramfis
Ramfis's Avatar
Thumbs up
V.
Exactly, thanks to all.
Old 02-06-18, 07:16 AM
2013FSport
2013FSport's Avatar
Received 1,529 Likes on 1,272 Posts
/OT - slightly...
Any of you having issues with poly bushings squeeking?
Old 02-06-18, 11:39 AM
zen
zen's Avatar
Originally Posted by 2013FSport
/OT - slightly...
mine squeeks when the temper is below around 40, and nothing above it. I heard it's normal for poly bushings.
Old 02-08-18, 10:54 AM
UCrazyKid
UCrazyKid's Avatar
OP, You are driving a 2013, NVH will be pretty much nothing. If you were in a 2008 with factory suspension (know to be harshest) you get a little more but completely acceptable. I went USRS from RR and absolutely love it. You can't really go wrong with either one.
Old 02-08-18, 03:16 PM
ISFPOWER
ISFPOWER's Avatar
had both. get the Figs if you want a smooth, OEM feel. if you live around PERFECT roads, get RR racing. otherwise, RR racing made me hate the ISF in terms of added NVH.
The following 4 users liked this post by ISFPOWER:
greys0uled (09-28-22), Hamed1 (07-01-20), henry1229 (06-01-18), Ramfis (02-16-18)
Old 02-08-18, 06:53 PM
Weapon F
Weapon F's Avatar
You are correct FIGS 90&80 durometer bushing will give you less NVH than 95 durometer RR racing bushings. If NVH is concern then go for less aggressive durometer.
Everyone is entitled to their opinion interesting statement "RR racing made me hate the ISF in terms of added NVH." I see you live in North Carolina your roads are no where near as bad as roads I drive on daily into NYC with pot holes, patched pot holes on top of patched pot holes, expansion joints, raised Steel plates that they use to cover section of roads that have pot holes or under construction try hitting one of those at 60 mph, ruts in road, bulges in asphalt, undulating roads. I have RR Racing URSR and daily drive into NYC daily along with other 900,000 people. Is there added NVH yes is as bad as you make it seem I don't know since NVH can be subjective. For me it's not that bad with my daily 42 mile commute. I've now added Superpro urethane bushings all around front ctr arms, rear car arms, trailing arms sway bars etc. Installing urethane bushings added way more NVH than RR Racing URSR bushing did. Once again just my opinion. Both companies make Quality Parts you can't go wrong with either one just find which one suits your driving needs.
Ramfis (02-16-18)
Old 02-08-18, 07:05 PM
ISFPOWER
ISFPOWER's Avatar
the RR racing ones were fine in NC. NC put a lot of money into their roads and roads were perfect everywhere which i loved. then i moved to IA/IL for work. The ride was unbearable . the bushings still did what they said they would do(great brake feel), but i could not live with the road noise and hard impacts of these lines these roads had in these states. the lines were where they fixed the road cracks from snow and cold weather and it was every 1 foot in the roads and you just feel it so hard. i switched out to the Figs and it all went away. then i went back to stock and it felt the same as Figs before i traded the car in. i think the Figs come with little groves in the bushings from what he told me to help with impact.
Also, both bushings were with BC coils/swift 16/12k springs lowered 2 inches i the front. but rr racing USRS were great in NC like you stated and you are correct with that.
Old 02-09-18, 07:15 PM
Ramfis
Ramfis's Avatar
Thanks toball I pulled the trigger on the figgs 90, and just arrived today. Hopefully I’ll install them through the weekend...!!!
Quick Reply: Figs or RR Racing LCA bushing?
