Sorry to bring up an old thread, but has there been any additional members running 18’s? I’m tryinf to determine my tire sizes as I just got new 18” 57dr’s like the OP.
I prefer to run a square setup on tires, but looking for the widest tires.
I had been running a 18x9.5 +45 square combo with 275 35 tires for more then 3 years. It has been great so far. I recently change from Enkei PF01 to WedsSport SA-20R. So far, I'm loving the look
what specs are these, and what suspension. It looks very good.
It really depends on the tires. Some 275s have a 9.7 inch tread width and some 265s have a 10.2 tread width. It’ll be very close, so I recommend having tires fitted at a shop where you can return them if they don’t fit. I’d start with normal 265s and go down from there. FYI a 255 on a 9.5 stretches enough that you have no outer rim protection. I have a 255 on a 9.5 just because it needed a tire, and if I lay it down the rubber doesn’t touch the ground, the rim lip does.
