VLand 2IS Taillights (Similar to 78Works & Spec-Ds)
#198
#199
Mine looked great. I had some concern about the gap others have mentioned, as it's quite obvious when tightening the unit down (root cause is black backing plastic lip isn't consistent from one side of light to other), but it's not really noticeable when completed. Only other gripe is I wish the amber color on the turn/hazard LED's was a bit deeper hue. Minor gripe though and perhaps just personal preference... I'd rate them a 9.5 out of 10 overall.
#201
No and Im not sure I would accept that. Mine had mild surface scratches that covered almost the whole surface of one, not serious enough to return. That scratch in picture three looks deep enough to be obvious and not repairable with a polish. And if Im seeing the first two pics right it looks like the seal is bad, if it doesnt leak at first it might in the future and moisture in a taillight looks like crap. Obviously you know best, a picture can be misleading...
#203
I still went around the entire edge of each light with a small bead of clear silicone..
#205
#206
I'll be doing the same once I get my replacement if the seller replies in a timely manner lol.
#207
