Starting After Winter Storage
Hey everyone,
My F has been sitting for about 3 months and with some nice weather inbound, I would love to take her out for a spin. What is the best way to ensure the engine reaches optimal lubrication and builds some oil pressure prior to firing up? I looked through the owner's manual for a fuel pump fuse but it seems more complicated than on the LS400 I had. I also have a feeling this wouldn't do the trick - I assume there might be enough fuel in the system for it to fire up.
Cheers
Cheers
Due to the complexity of removing the plugs this might not be an option, but you could change the oil and remove the plugs. Turn the engine over a few times to allow lubrication and then reinstall/replace the plugs.. I've only done this on older vehicles, so again might not be what you are looking for
Hey everyone,
Cheers
Cheers
if you have techstream you can put it into compression test mode, and it won't start or deliver fuel, it will just turn over for as long as you hold the start button.
rw3 (03-05-18)
Hey everyone,
Cheers
Cheers
LOL, I actually didn't end up taking it out. Missed the opportunity and now snow has returned for at least another week or two. Have to wait for all the salt to wash away again...
Started my car after 4 months of winter storage. Have it plugged in to a battery tender. The only thing that got me a little worried was the rock hard brake pedal when I went to start it up...turned over smooth, and brake pedal went back to normal operation after pressing the brakes a few times
LOL, I'm in the same boat. A warm day will tempt me but then the next the temp plunges below freezing again. Anything below 45F and my summer only tires are worthless. Waiting patiently...
My car is stored from November to roughly the end of April.. I've never had any issues with starting the car up in the spring.. My car is also on a trickle charger to keep the battery juiced. I usually hit the start button twice, let all the lights come on and then fire it up.. It usually takes a few cranks before it fires up - one time it even misfired and threw a check engine light. However it sorted itself out and once the car was up to temp it was fine.. check engine light went out in a day
Migros
05-31-18 05:57 PM
