Opinions on 2012 IS-F in Albuquerque
I found this IS-F at the Lexus of Albuquerque
https://www.lexusofalbuquerque.com/V...s?model=IS%20F
I would more than likely be trading my 2013 GS350 for it.
What do you guys think?
I plugged in the VIN on Lexus drivers but that site seems to be down or not working well right now.
Yeah the site is working now: Seems like the car was lowered and had some aftermarket parts on it? Also, some other stuff that the original owner brought to the Lexus dealer.
Doesn't the IS-F have a "big" 60,000 mile service?
77939 MILES
DATE: 02/08/2018REPAIR# 0254601REPORTED BY: Lexus of Albuquerque
SERVICE: * SYN LOFDESCRIPTION: * SYN LOF ~ ~PERFORM LUBE, OIL & FILTER SERVICE WITH SYNTHETIC OIL ~ ~SCHEDULED MAINTENANCE ~ ~PERFORMED LUBE, OIL & FILTER SERVICE SYNTHETIC OIL
SERVICE: AUTO DETAILINGDESCRIPTION: AUTO DETAILING ~ ~PERFORM COMPLETE INTERIOR & EXTERIOR DETAIL ~ ~DUE TO TIME OR MILEAGE ~ ~DETAIL COMPLETED
SERVICE: EMISSIONS INSPECTIONDESCRIPTION: EMISSIONS INSPECTION ~ ~PERFORM EMISSIONS INSPECTION ~ ~EMISSIONS INSPECTION REQUIRED ~ ~EMISSIONS INSPECTION COMPLETED
SERVICE: OTHER INSPECTIONDESCRIPTION: OTHER INSPECTION ~ ~USED CAR CHECK ~ ~FOUND INSIDE OF ALL TIRES WORN. FOUND AFTERMARKET BRAKES FRONT AND REAR WITH GLAZED ROTORS. RECOMEND TIRES AND FRONT AND REAR BRAKE JOBS WITH ROTORS AND SHIMS ~ ~INSPECT ENGINE, TRANSMISSION & POWERSHOW LESS
77857 MILES
DATE: 02/01/2018REPAIR# 0254319REPORTED BY: Lexus of Albuquerque
SERVICE: BATTERY/COIL SPK PLUGDESCRIPTION: BATTERY/COIL SPK PLUG ~ ~OWNER STATES STEERING FEELS STIFF. CHECK AND ADVISE. ~ ~NO PROBLEMS WITH STEERING FOUND AT THIS TIME. ~ ~SCENNED VEHICLE, NO FAULTS FOUND. BATTERY NEEDED RECHARGE. RECHARGED & CHECKED. OK.
75297 MILES
DATE: 08/16/2017REPAIR# 0613964REPORTED BY: Earnhardt Lexus
SERVICE: BRAKE GROUPDESCRIPTION: BRAKE GROUP ~ ~CLIENT STATES WHEN BRAKING AT FREEWAY SPEEDS THE VEHICLE HAD A HARD VIBRATE WHEN COMING TO A STOP. HAPPENED A SECOND TIME LIKE A WHEEL WAS STUCK WHEN TRYING TO TURN ~ ~ ~ ~75297 TEST DRIVE VEHICLE FOUND VIBRATION COMING FROM SHOW LESS
SERVICE: PERFORM MULTI POINT INSPECTION ON VEHICLEDESCRIPTION: PERFORM MULTI POINT INSPECTION ON VEHICLE ~ ~PERFORM MULTI POINT INSPECTION ON VEHICLE ~ ~REQUEST TO PERFORM MULTI POINT INSPECTION FOR CUSTOMER VEHICLE INSPECTION
74710 MILES
DATE: 08/10/2017REPAIR# 0244570REPORTED BY: Lexus of Albuquerque
SERVICE: 75000 MILE SERVICE NON WARRANTYDESCRIPTION: 75000 MILE SERVICE NON WARRANTY ~ ~CUSTOMER REQUESTS 75000 MILE SERVICE NO TIRE WORK, CHECK PSI ONLY. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGINE OIL AND FILTER; INSPECT AND MEASURE TIRES, CHECK WEAR AND SET PROPER INF... READ MORE
71265 MILES
DATE: 04/07/2017REPAIR# 0532639REPORTED BY: Lexus Carlsbad
SERVICE: BATTERY/COIL SPK PLUGDESCRIPTION: BATTERY/COIL SPK PLUG ~ ~C/S BATTERY FAILED > HAD TO JUMP START TO GET TO DEALERSHIP > BATTERY WAS REPLACED 07/13/15 MILES: 48748 RO#201688 INSTALLED LEXUS OF ALBUQUERQUE > REPLACE IF REQUIRED ~ ~INSPECTION FINDS INTERNAL FAILURE I... READ MORE
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~CHECK DRIVERS FLOOR MAT FOR PROPER INSTALLATION ~ ~COURTESY INSPECTION FOR PROPER INSTALLATION ~ ~DRIVER'S MAT IS PROPERLY INSTALLED AT THIS TIME.
SERVICE: OTHER INSPECTIONDESCRIPTION: OTHER INSPECTION ~ ~FOR YOUR CONVENIENCE OUR LEXUS CERTIFIED TECHNICAL STAFF WILL BE PERFORMING A TIRE PRESSURE CHECK ON YOUR VEHICLE WHILE IT IS HERE, INCLUDING TIRE PRESSURE ADJUSTMENT TO THE SPECIFICATION OF THE VEHICLE MANUFACTURER. . T... READ MORE
SERVICE: OTHERSDESCRIPTION: OTHERS ~ ~TO AVOID A CHARGE OF $4.95 A GALLON, PLEASE REPLACE ALL OF THE FUEL YOU USE. TO AVOID A CHARGE OF $65.00 A DAY, PLEASE RETURN THE LOANER VEHICLE WITHIN 24 HOURS OF YOUR VEHICLES COMPLETION. IF A LEXUS LOANER IS NOT AVAILABLE YOU W... READ MORE
69961 MILES
DATE: 03/15/2017REPAIR# 0235991REPORTED BY: Lexus of Albuquerque
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~PERFORM SAFETY CHECK. ~ ~SCHEDULED MAINTENANCE ~ ~NO RECOMMENDATIONS AT THIS TIME.
64696 MILES
DATE: 10/26/2016REPAIR# 0228300REPORTED BY: Lexus of Albuquerque
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~PERFORM LUBE, OIL & FILTER SERVICE ~ ~SCHEDULED MAINTENANCE ~ ~PERFORMED LUBE, OIL, & FILTER SERVICE
59304 MILES
DATE: 06/01/2016REPAIR# 0219822REPORTED BY: Lexus of Albuquerque
SERVICE: 60000 MILE SERVICE NON WARRANTYDESCRIPTION: 60000 MILE SERVICE NON WARRANTY ~ ~CUSTOMER REQUESTS 60000 MILE SERVICE NO TIRE WORK. CHECK PSI ONLY. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGINE OIL & FILTER; INSPECT TIRES; ADD FUEL INJECTION CLEANER AND PERFORM SHOW LESS
52749 MILES
DATE: 12/15/2015REPAIR# 0210792REPORTED BY: Lexus of Albuquerque
SERVICE: 50000 MILE SERVICE NON WARRANTY-NON OEMDESCRIPTION: 50000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 50000 MILE SERVICE NO TIRE ROTATION DUE TO STAGGERED WHEELS. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGINE OIL AND FILTER; INSPECT TIRES, CHECK WEAR AND SET PR... READ MORE
48748 MILES
DATE: 07/13/2015REPAIR# 0201688REPORTED BY: Lexus of Albuquerque
SERVICE: BATTERY/COIL SPK PLUGDESCRIPTION: BATTERY/COIL SPK PLUG ~ ~OWNER STATES VEHICLE NEEDED TO BE JUMP STARTED RECENTLY. CHECK CHARGING SYSTEM AND ADVISE. CHECK CONDITION OF ATTACHING CABLES & CLEAN AS NEEDED. ~ ~ORIGIONAL BATTERY WAS PANASOINC. BATTERY FAILED LOAD TEST ~ ~R... READ MORE
46630 MILES
DATE: 06/25/2015REPAIR# 0200522REPORTED BY: Lexus of Albuquerque
SERVICE: 45000 MILE SERVICE NON WARRANTYDESCRIPTION: 45000 MILE SERVICE NON WARRANTY ~ ~CUSTOMER REQUESTS 45000 MILE SERVICE OWNER REQUEST NO TIRE WORK. CHECK PSI ONLY. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGING OIL & FILTER; INSPECT TIRES, CHECK WEAR AND INFLATE TO... READ MORE
SERVICE: ELECT/MODULATED AIR SUSPNSN AIRBAG SYSTEMDESCRIPTION: ELECT/MODULATED AIR SUSPNSN AIRBAG SYSTEM ~ ~OWNER STATES SCALE IN PASSENGER SEAT MAY NEED CALIBRATION. CHECK AND ADVISE. ~ ~CHECKED FOR CODES NO CODES PRESENT ~ ~PERFORMED RECALABRATION OF PASSENGER SEAT SENSOR FOR AIR BAG. TESTED SYSTEM.... READ MORE
SERVICE: FRONT AXLEDESCRIPTION: FRONT AXLE ~ ~OWNER STATES EXCESSIVE SOUND FROM HUB. REQUEST TEST DRIVE WITH TECHNICIAN TO AID IN DIAGNOSIS. ~ ~SOUND HEARD IS FROM TIRES. ~ ~SEE JOB #5.
SERVICE: SEE SECTIONDESCRIPTION: SEE SECTION ~ ~OWNER STATES A/C SHUT OFF ON IT'S OWN. CHECK AND ADVISE. ~ ~INSPECT CONDENSER, CONDENSER, RECEIVER/DRYER, ALL LINES AND HOSES. CHECK FREON LEVEL. EXAMINE SYSTEM FOR LEAKS. CHECKED FOR CODES NO CODES PRESENT CHECKED A/C CABIN SHOW LESS
SERVICE: WHEEL ALIGNMENTDESCRIPTION: WHEEL ALIGNMENT ~ ~FOUR WHEEL ALIGNMENT ~ ~FRONT AND REAR TOE OUT OF SPEC ~ ~ALIGNMENT COMPLETED TO MANUFACTURER'S SPECIFICATIONS
46253 MILES
DATE: 06/11/2015REPAIR# 0199752REPORTED BY: Lexus of Albuquerque
SERVICE: FLAT TIRE REPAIRDESCRIPTION: FLAT TIRE REPAIR ~ ~CUSTOMER STATES TIRE IS LOSING PRESSURE. ~ ~OBJECT IN TIRE ~ ~FOUND LR TIRE LOSING AIR DUE TO OBJECT IN TIRE. REPIARED AND BALANCED TIRE.
42675 MILES
DATE: 01/22/2015REPAIR# 0191554REPORTED BY: Lexus of Albuquerque
SERVICE: 40000 MILE SERVICE NON WARRANTY-NON OEMDESCRIPTION: 40000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 40000 MILE SERVICE OWNER REQUEST NO TIRE ROTATION. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE LABOR CHARGE REFLECTS DISCOUNT. ~ ~REPLACE ENGINE OIL AND FILTER; INSPECT TIRES,... READ MORE
37090 MILES
DATE: 11/17/2014REPAIR# 0187893REPORTED BY: Lexus of Albuquerque
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~PERFORM LUBE, OIL & FILTER SERVICE LABOR CHARGE REFLECTS -15% DISCOUNT. ~ ~SCHEDULED MAINTENANCE ~ ~PERFORMED LUBE, OIL, & FILTER SERVICE
33208 MILES
DATE: 09/09/2014REPAIR# 0183602REPORTED BY: Lexus of Albuquerque
SERVICE: RADIO TUNER ASSEMBLYDESCRIPTION: RADIO TUNER ASSEMBLY ~ ~OWNER STATES SUB WOOFER MAY BE OUT. CHECK AND ADVISE ~ ~FOUND RADIO AMP HAS INTERNAL MALFUNCTION CAUSING POOR SOUND QUALITY. OPN=86280-0W750 ~ ~GAINED ACCESS AND REPLACED RADIO AMP
32963 MILES
DATE: 09/03/2014REPAIR# 0183234REPORTED BY: Lexus of Albuquerque
SERVICE: RADIO TUNER ASSEMBLYDESCRIPTION: RADIO TUNER ASSEMBLY ~ ~OWNER STATES SUB WOOFER MAY BE OUT. CHECK AND ADVISE. ~ ~ ~ ~REORDERING STEREO AMP
32823 MILES
DATE: 08/26/2014REPAIR# 0182577REPORTED BY: Lexus of Albuquerque
SERVICE: NON WARRANTABLE OPERATION CODEDESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~OWNER REQUEST RIM REPAIRS. ~ ~OWNER REQUEST. ~ ~REPAIRED RIGHT FRONT RIM AS NEEDED.
SERVICE: OTHERSDESCRIPTION: OTHERS ~ ~OWNER STATES ABNORMAL SOUND COMING FROM ENGINE AREA WHILE VEHICLE IS RUNNING. CHECK AND ADVISE. ~ ~SCREW FOR COOLING FAN MOTOR VIBRATED LOOSE. ~ ~INSPECTED VEHICLE FOR EXCESSIVE SOUND & FOUND IS COMING FROM A MISSING SCREW OUT... READ MORE
SERVICE: RADIO TUNER ASSEMBLYDESCRIPTION: RADIO TUNER ASSEMBLY ~ ~OWNER STATES SUB WOOFER MAY BE OUT. CHECK AND ADVISE. ~ ~ ~ ~NEW AMP ON ORDER.
32068 MILES
DATE: 07/31/2014REPAIR# 0181241REPORTED BY: Lexus of Albuquerque
SERVICE: 30000 MILE SERVICE NON WARRANTYDESCRIPTION: 30000 MILE SERVICE NON WARRANTY ~ ~CUSTOMER REQUESTS 30000 MILE SERVICE LABOR CHARGE REFLECTS -15% DISCOUNT. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGINE OIL AND FILTER; ROTATE AND BALANCE TIRES, CHECK WEAR AND INFLATE... READ MORE
SERVICE: OTHERSDESCRIPTION: OTHERS ~ ~PERFORM FRONT BRAKE SERVICE LABOR CHARGE REFLECTS -15% DISCOUNT. ~ ~FRONT BRAKE PADS WORN BELOW 2MM ~ ~INSTALLED NEW FRONT BRAKE PADS; SERVICE/TRUE FRONT BRAKE ROTORS; CLEAN & LUBE FRONT BRAKE CALIPERS; TEST DROVE VEHICLE, PER... READ MORE
SERVICE: WHEEL ALIGNMENTDESCRIPTION: WHEEL ALIGNMENT ~ ~FOUR WHEEL ALIGNMENT LABOR CHARGE REFLECTS -15% DISCOUNT. ~ ~SCHEDULED MAINTENANCE ~ ~ALIGNMENT COMPLETED TO MANUFACTURER'S SPECIFICATIONS
27043 MILES
DATE: 03/12/2014REPAIR# 0172904REPORTED BY: Lexus of Albuquerque
SERVICE: 25000 MILE SERVICE NON WARRANTY-NON OEMDESCRIPTION: 25000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 25000 MILE SERVICE NO TIRE WORK. CHECK PSI ONLY. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGINE OIL AND FILTER; ROTATE TIRES, CHECK WEAR AND SET PROPER INFLATIO... READ MORE
SERVICE: RADIO TUNER ASSEMBLYDESCRIPTION: RADIO TUNER ASSEMBLY ~ ~OWNER WOULD LIKE OPERATION OF AUDIO SYSTEM CHECKED. STATES PREMIUM SOUND SYSTEM NOT OPERATING CORRECTLY. ~ ~COULD NOT DUPLICATE ONWERS CONCERN. COMPARED TO OTHER F VEHICLES AT DEALERSHIP. ~ ~INSPECTED SPEAKER SYSTEM ... READ MORE
15489 MILES
DATE: 08/22/2013REPAIR# 0160975REPORTED BY: Lexus of Albuquerque
10597 MILES
DATE: 06/07/2013REPAIR# 0156688REPORTED BY: Lexus of Albuquerque
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEMDESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~ ~CUSTOMER REQUESTS 10000 MILE SERVICE DIRECTIONAL TIRES, NOT ABLE TO ROTATE TIRES. ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGINE OIL AND FILTER; INCPECT TIRES, CHECK WEAR AND SET... READ MORE
4856 MILES
DATE: 03/13/2013REPAIR# 0152049REPORTED BY: Lexus of Albuquerque
SERVICE: 5,000 MILE SERVICEDESCRIPTION: 5,000 MILE SERVICE ~ ~CUSTOMER REQUESTS 5000 MILE SERVICE ~ ~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~ ~REPLACE ENGINE OIL AND FILTER; ROTATE TIRES, CHECK WEAR AND SET PROPER INFLATION PRESSURES; INSPECT ENGINE AIR FILTER, BRAKE LINING... READ MORE
SERVICE: INTERNALTRUNKRELEASEDESCRIPTION: INTERNALTRUNKRELEASE ~ ~OWNER REQUESTS PERFORMANCE OF PRODUCT UPDATE DLB ~ ~ON SOME MODEL VEHICLES THE TRUNK RELEASE LEVER (HANDLE) CAN BREAK IF NOT PULLED IN THE DIRECTION SPECIFIED ON THE HANDLE. ~ ~REPLACED TRUNK RELEASE LEVER (HANDLE) M... READ MORE
SERVICE: RADIO TUNER ASSEMBLYDESCRIPTION: RADIO TUNER ASSEMBLY ~ ~OWNER STATES SATELLITE RADIO EQ SOUNDS ""FLAT"" COMPARED TO FM STATION RECEPTION. CHECK AND ADVISE. ~ ~NO PROBLEMS FOUND AT THIS TIME ~ ~NO REPAIRS PERFORMED, NEEDED OR RECOMMENDED AT THIS TIME.
2718 MILES
DATE: 01/18/2013REPAIR# 0149331REPORTED BY: Lexus of Albuquerque
SERVICE: FLAT TIRE REPAIRDESCRIPTION: FLAT TIRE REPAIR ~ ~CUSTOMER STATES TIRE IS LOSING PRESSURE. OWNER STATES DRIVER SIDE FRONT TIRE. ~ ~OBJECT IN TIRE ~ ~PATCHED LEFT FRONT TIRE
1058 MILES
DATE: 11/29/2012REPAIR# 0146701REPORTED BY: Lexus of Albuquerque
SERVICE: 1,000 MILE SERVICEDESCRIPTION: 1,000 MILE SERVICE ~ ~CUSTOMER REQUESTS 1,000 MILE SERVICE AND LEXUS PERSONALIZED SETTINGS SERVICE ~ ~INSPECT BODY AND CHASSIS; CHECK VEHICLE FOR FLUID LEAKS; ROAD TEST VEHICLE; PROGRAM LEXUS PERSONALIZED SETTINGS ~ ~PERFORMED ALL REQUIRED... READ MORE
477 MILES
DATE: 11/14/2012REPAIR# 0145850REPORTED BY: Lexus of Albuquerque
SERVICE: AUTO DETAILINGDESCRIPTION: AUTO DETAILING ~ ~PERFORM COMPLETE INTERIOR & EXTERIOR DETAIL RECENT PURCHASE ~ ~OWNER STATISFACTION PER FOLLOW UP SALES CALL. ~ ~DETAIL COMPLETED
8 MILES
DATE: 04/25/2012REPAIR# 0134208REPORTED BY: Lexus of Albuquerque
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDESDESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~PERFORM PRE-DELIVERY INSPECTION ~ ~REQUIRED ~ ~PDI COMPLETE
SERVICE: WINDOW PROGRAMMINGDESCRIPTION: WINDOW PROGRAMMING ~ ~PROGRAM KEYLESS ENTRY SYSTEM TO OPEN ALL WINDOWS WHEN ""OPEN"" BUTTON IS DEPRESSED FOR 3 SECONDS ~ ~NEW VEHICLE PREPARATION ~ ~KEYLESS ENTRY SYSTEM PROGRAMMED TO OPEN ALL WINDOWS WHEN ""OPEN"" BUTTON IS DEPRESSED FOR 3... READ MORE
I honestly think its a little expensive for those miles but at the same time in my year plus of searching, 2011+ Nebula Grey, Matador Red and Ultrasonic Blue are very rare to pop, but even thou I think its a little overpriced it is also not a scam. plus I'm pretty sure you can get them to drop that price a little.
I am actually an internet manager at Lexus of Albuquerque. This vehicle is extremely nice and the owner did have every service done here at the dealership. He spent over $6000 on services over the life of the vehicle. It does not have aftermarket parts on it. It was an older gentleman that owned and lived close to me so I saw him often driving the car before I met him after I started working at the dealership. He loved the car but getting older he did not like getting in and out of it. He sold it to us and purchased a new Porsche Macan
I bought my 2011 from Carmax a couple of weeks ago. I paid about the same for a similar condition car with 44k on the ODO. This one looks to be in great condition, especially with the dealer doing all of the service work.
Yeah 2011-2014 ISF's are rare regardless, I bought mine from California a month ago and it took me almost a year to find the right color miles and price, I wanted a Matador red or Nebula Grey and those 2 colors very rarely appear. I'm from Orlando by the way had to get it shipped
right color but that price is too high for an 80k car..
http://www.tampabayautonetwork.com/d...-17345891.html
LatinLS430 (03-06-18)
Very clean car and well maintained. $36k is a steal for the car....once you own it, you'll agree! Don't penny punch and lose your opportunity to buy an AWESOME car! I've loved every second of my '12 F!
im sure you could find a "lower price" but I'm sure that'll come with defects, questionable maintenance history, in need of tires/brakes, etc, possibly accidents. Pull the trigger!!
V.
V.
you're clueless. This car is priced well, especially considering the color combo and year.
OP, if you can get them to budge a couple of grand off the asking price, you are doing REALLY well. It's definitely even worth paying asking price for it. Nebula Gray/Red is very hard to find.
