Any way to show digital speedometer in 09 isf?
Really annoyed no digital speedometer in 09isf.
Any way to show that? I always ended up speed much more than I'd like! Afraid I'll get a ticket any second.
You mean an OEM way? Nope. I hate it on my 08 too. Was almost tempted to get an 11+ just for that feature.
If you want it on the OEM Navi screen the Grom VLine is probably your best/only option. It uses its own GPS and isn't perfect but better than nothing for sure. I use it daily. I'd imagine there is likely a way to hook it up to an OBD2 scanner to get speed through the OEM sensors but I haven't tried that.
If you are alright with another screen being used, like your phone then you can likely use a wireless OBD2 scanner to do that. Some GPS apps like Waze show it by default also. Or if you want a completely separate device then maybe something like a Garmin/TomTom GPS.
There's an androids app called torque that i used with a Bluetooth obd2 scanner that has digital display dashboards you can customize. It worked on my S2000. I have the digital speedometer on my 2012 so I never had the torque app tested on the F. I would think it would work too.
Get a radar detector with GPS that shows your speed is the next best thing
yeah this is why I was so stubborn on my search for 2011+ Lexus ISF the little stuff.
I wonder if the 08-10 models cluster is interchangeable with a 11+ or if anybody has tried to do so.
Looks like the forum pondered this six years ago, but it went nowhere. Someone even verified the harness was the same.
https://www.clublexus.com/forums/is-...-2010-a-2.html
