Key not detected please help.
Hey everyone I’m having a strange issue with my car whenever I turn the car off and open the door it starts to beep and when I close the door and try to lock the doors with the key fob it won’t and the screen in the gauge displays key not detected . I have to wait a few minutes before I can lock the car with the key fob. I replaced both batteries on the fobs and the problem is still there. So I’m kind of out of ideas and need help to figure out the issue. Thanks again.
Remove battery from key fob and place it close to start button and see if you can start your car that way. If you can't, your key code is somehow not "seeded" anymore and it needs to be paired up with the computer again, I think.
Give that manual startup a try first...
So another idea is the proximity computer (door lock) is not recognizing the key fob's code. The steering column computer (startup) is separate from the proximity one, so I think you should get this looked by a stealership technician, or anyone that has a Techstream.
Proximity computer door lock? Hmmmm well the rear passenger door ajar sensor was replaced by the bodyshop that repaired my car could that have something to do with it?
Tech Info Resource
Maybe, but Techstream is the only way you'll be able to troubleshoot this after trying all the simple stuff.
I was having the same problem. Doors weren't unlocking from time to time but the car was starting no problem. Ended up being just the batteries in the fob itself. I bought new ones from London Drugs when I first got the car. But it was still doing it. Had to search for Energizer Max batteries and never had the problem with the doors again.
