Best product for anti squeal lube?
What are you guys using to lube your brake pad anti squeal plates? Tried searching, but the answer is likely buried in page-deep brake threads and hoping it is easier to go this route. I see Brembo launched something called B Quiet, however, doesn’t appear to be available online anywhere. Other suggestions?
Recently changed my brakes up and bought this(recommend somewhere on the forums) . Zero squeal with my oem brembo rotors and duralast gold pads.
Here is one thread that may help also https://www.clublexus.com/forums/is-...ke-grease.html
I use the Permatex copper. Put a good coat across the whole back of the shim where it mates to the pad.
Permatex 09128 Copper Anti-Seize Lubricant, 8 oz. https://www.amazon.com/dp/B000HBM8HU/ref=cm_sw_r_cp_api_uSk2Ab23YQANG
I did a couple brake bed-in and fixed my horrible squealing. Hasn't heard a peep in the last couple weeks. The front brakes are about a couple years old, by the way.
The clunking is a physical size (of the pad) problem. It is unlikely the lube will do anything for that. The lube is typically for vibration that results in squeal.
SynicalVip
03-01-13 01:27 PM
