GSF/RCF LCA bushings in ISF
#32
Tech Info Resource
No. Won't work. They moved things around when the redesigned the front suspension. The ball joints are not in the right places to do this. I looked at it when we got the GS F.
#36
I would make a lower durometer version of our USRS bushings, if I felt that the NVH was the slightest issue. I find it odd that someone driving an ISF or RCF would be bothered by having a much more stable car and more communicative steering. I guess Lexus engineers know who they are catering to when they engineer the life out of their otherwise great cars.
But seriously, to say that NVH is an issue with our bushings, you’d have to have a butt with the sensitivity of a seismograph!
As far as LCA bushings go, don’t forget, the USRS is the only bushing that eliminates AXIAL movement of the LCA, due to our thrust loaded design.
Rafi
https://www.rr-racing.com/Lexus-Lowe...isfxlca002.htm
MileHIFcar (02-21-21)
#37
Good to know there are some other options out there to suit different needs for owners👍
vraa (02-21-21)
#38
Tech Info Resource
No doubt. Love my solid bushings, but they definitely transmit more high frequency noise to the chassis and sharp bumps have a completely different feel than before. And there's zero axial movement with these unless the aluminum is flexing.
Under car from the starter replacement:
The following 2 users liked this post by lobuxracer:
MileHIFcar (02-25-21),
vraa (02-25-21)
FIGS
CL Vendor Products for IS-F
09-03-16 08:27 AM
