Request: EL PPE headers dyno & review
Hello,
I've been researching on this for quite a bit lately since I'm at the pivotal point of getting headers. After reading through two old threads discussing the introduction of EL LT headers and the aftermath of installation (it was "retrofitted" from the ones made for RCF at the time), I would like some feedback from those who had them for a some time. Additionally, there was one person who provided dyno and run times with both EL and UEL. However, there was a significant time variance between the baseline run and the post-installation run.
If anyone can chime in on this, it would be greatly appreciated. If there is another thread with most recent development that I missed, please also kindly link me to that.
Thanks.
P.S., this thread is not primarily asking for sound clip as I have heard a bit of them provided by a member in the old threads. However, they are most welcome if you have any!
Thanks.
Wow, this could not have been more timely. I'm in your exact same boat. I'm 90% sure my stock manifolds are cracked, so I'll need something soon, and since I'm looking at going the SC route soon, headers would be a no-brainer.
The EL's are purported to have a more "stock" sound in the sense that they keep the "high-tech" Euro-burble qualities of the stock sound... which I really like. But at such a cost premium, I'm a bit torn...
Feedback mutually appreciated!
I've been reading here and there stuff as well for quite sometime now and I think at the end of the day difference between EL and UEL is, EL are almost a $1000 more but they also sound 1000 times better and they also reduce drone significanlty, and that performance wise they are the same neither one gives you more power than the other that's worth mentioning.
Take my opinion with a grain of salt since I don't own neither and only basing my comments on what I've read here on the forums
Leander311 (05-04-18)
I went from sikky headers to EL ppe headers but I mainly did it for the sound and not for any power increase because I knew it'd be very small or none at all. The car also has the borla exhaust and the tuned intake so my experience is based on those mods as well.
The sound changes noticeably with the EL headers. It becomes less lumpy and more linear. The exhaust also quieted at certain RPMs. The drone it's still present but it's higher pitch. It might be placebo but it also seems as if the car revs faster. I also like to rev it higher between shifts, more so than before. At lower speeds at around 3k RPM, you can sort of hear the wind blowing trough the pipes. Like when you blow through a pipe or on a beer bottle.
I know a few people with UL ppe headers. I'll see if we can get together to compare them.
I've been running UEL for about 2 years now with no problems. Its paired to a Joe Z exhaust and I think the sound is great. There is a little bit of drone around 2K RPM but it is really not that bad in my opinion. I really like the idea of EL headers, but being that they don't produce any more power, and the main difference is sound, I just can't justify selling mine and spending $1200 more to get EL.
My Post from another thread:
Lou
I've had both on my ISF. Measured power output on a dyno was about the same. But, the measurements were done over 3 years apart with different wheels. The big difference is sound. UL length headers have more of a V8 lumpy sound. The EL are a bit higher in pitch and smoother in sound. There is also more drone with the UL headers. I also have the PPE Dual Mode exhaust and with the UL headers I was unable to make and receive bluetooth phone calls with the valves in the open position. With the EL headers I now can. The valves on my exhaust now stay open 99% of the time. With the UL headers I left the valves open maybe 60% of the time.
The EL sounds soo good. Can't replicate that sound. I had unequal on my ISF and I loved every bit of it.. However, if I could go EL I would.. (They didn't have it at the time when I had my modded ISF).
No reported issues with fitment on the Equal or unequal as of yet through my customers or PPE.
Contact us for pricing!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
1200 more, but since you're going S/C route you may want to consider EL more due to the sustained benefits of reduced residual heat that would otherwise be damaging the ringlands. The posited theory is that the unequal length will have residual heat from exhaust being pushed back into the cylinders whereas EL reduces the extent of that damage (no elimination as I understood). For your long-term consideration, you may have to get EL.
AFIK, all of the s/c tunes for the isf were created on vehicles utilizing unequal length headers. Is there any evidence to support the posited theory?
In the "offical exhaust system setup discussion/video/news thread" post on CL, there is a video of an ISF with Arqray exhaust and EL headers. That car sounds amazing. When I get headers, I will spend the extra money for the EL headers just for the sound. After all, for me, headers will be a one time purchase. I say F it.
"An equal length header will expel gases at an equal rate per pulse, with gas from each cylinder leaving the header at the same time. With an unequal length header, gas from the two longer runners will remain in the header as it will take longer to reach the collector -- this results in lower cylinder temperature on an equal length header, which can help prevent ringland failure. Another benefit of equal length headers is the balance of backpressure at the exhaust ports, which will improve volumetric efficiency and overall top end performance."
The explanation makes sense given my VERY limited understanding of thermodynamics and general physics, but there is no empirical evidence (not that I know of) supporting this theory.
Zeitaku
10-14-19 12:01 PM
NYC ES3
IS F (2008-2014)
42
04-09-18 08:34 PM
