How to turn off the factory TPMS?
Old 05-12-18, 08:11 PM
Alizia
Alizia's Avatar
Default How to turn off the factory TPMS?
Ok this may be weird question to ask, but the factory TPMS doesn't tell you the psi of your tires... so when I upgraded my wheels and got brand new tires I also purchased an aftermarket TPMS. This new TPMS is super cool where it tells my PSI of each tire and updates every 10 seconds (or more). But... the tire pressure warning light lit up on my dash... and the old sensors are in my old wheels of course. I was wondering if there was a way to permanently turn off that stupid light because it's bothersome and since I use an aftermarket TPMS with its own LCD screen I won't need to see it. Any help would be much appreciated.
I attached a picture of one of my new wheels to keep this thread from being boring. It is a Litespeed Racing CB10 19x9 (front) & 19x10 (rear).
Old 05-12-18, 08:17 PM
xaker777
xaker777's Avatar
Nice wheels!! what brand your sensors are? I been looking for smart one for a while on my other cars. Can't find one that has good reviews. One of the way I can think of is removing the light from the dash board? Shouldn't be too complicated...
Old 05-12-18, 08:23 PM
Joker4096
Joker4096's Avatar
You can't turn them off as far as I know. You can make a cylinder and place the stock ones inside. Then pressurise it so the car thinks the tpms are in the wheels with optimal pressure.
Old 05-12-18, 08:29 PM
flowrider
flowrider's Avatar
Received 1,949 Likes on 1,372 Posts
^^^^Called a pipe bomb:
https://www.clublexus.com/forums/is-...pipe-bomb.html
Lou
Old 05-13-18, 08:34 AM
liquidtek
liquidtek's Avatar
All of my tpms are just in the spare tire in the trunk.
Old 05-13-18, 10:05 AM
BlckGhst
BlckGhst's Avatar
Which TPMS system did you go with?
Old 05-13-18, 03:00 PM
Alizia
Alizia's Avatar
I went with this one here:
https://www.amazon.com/gp/product/B0111PVHR2/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0111PVHR2/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
Orange Wireless Tire Pressure Monitoring System
It's awesome and I highly recommend it, tells me the PSI (which the factory TPMS doesn't for some reason) and a whole other crap that I don't care about lol.
Old 05-13-18, 03:18 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,082 Likes on 2,474 Posts
The factory sensors do all this as well, but for some reason (probably to avoid owners asking dumb questions) they left out this capability on a performance platform. I would totally understand if this were a classic Lexus where the owners know next to nothing about their cars, but on this one it just doesn't make sense. All the later F models have pressure readings on the combination meter.
tas02 (05-14-18)
Old 05-13-18, 05:44 PM
Pushtape
Pushtape's Avatar
Do 'all this' such as what? I have always wondered if it was possible to monitor the actual numbers from OBD app somehow. I know nothing about how tpms communicates to that light to trigger though.
Old 05-13-18, 06:57 PM
Joker4096
Joker4096's Avatar
I just checked the OBD Fusion app and in the Toyota PIDs, I found tire pressure readings that are similar or named the same as Techstream. I will add them and see if they register tomorrow.
Old 05-14-18, 10:14 AM
mikersoft
mikersoft's Avatar
Can't you just program the new sensors as the second set to get rid of the warning light? Unless I'm mistaken, there's only-way communications taking place (sensors --> ecu and/or device). If that's the case, then both the OEM & aftermarket systems should be able to read the sensor output simultaneously.
-Mike
Old 05-14-18, 10:44 AM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
-Mike
They may not be compatible with the Lexus system. TPMS doesn't have a data standard everyone follows.
mikersoft (05-17-18)
Old 05-15-18, 08:59 AM
xaker777
xaker777's Avatar
So... any luck?? I'd love to have this on my fushion!
Old 05-15-18, 09:10 AM
Joker4096
Joker4096's Avatar
I checked but nothing registers. There are a few options for each sensor so I will try each one and see.
Old 05-15-18, 10:10 AM
Joker4096
Joker4096's Avatar
Looks like I need a special adapter and to connect to the specific portion for TPMS.
Quick Reply: How to turn off the factory TPMS?
