Dyno before and after Headers 🤷🏼*♂️
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/1000x2000/screenshot_20180724_102330_a9001ec19284734a7ea5970e0d5d3f6d59081f9f.png)
Orange is before blue is after PPE headers. Dyno is practically the same. The temperature during Dyno was about 32F before headers and 96F after. The tech noticed the AF to be around 13.3 vs in the 12s before. Just curious what you guys think. Mods are FBO, RR tuned intake, Magnaflow Cats and Exhaust. TIA.
~Dv8
You need to remove the cover on the RR intake for best results per RR with the tuned intake on a dyno. Also you should have went with comparable temps. A 60 deg difference is obviously going to rape your IAT which vastly affects your timing so its not even really a fair comparison.
yoshua60 (07-25-18)
Blue graph looks bumpy like it’s pulling timing. The air temp is definitely affecting power output. The leaner af ratio indicates more air is flowing, all else being equal
Here in Indy we can see cars ET change by a half second between the humid summer and the cool fall. It makes a massive difference. You should make sure you have a good tune and just dyno when the temperature drops again, this time with the air box lid off. Your numbers will be better.
yoshua60 (07-25-18)
Magnaflow Exhaust and hiflow cats
Lol. Especially HTX! But its the weather. I scheduled it around work, and I got lucky with a cold front in the winter.
What's your KCLV out of curiosity
I can’t wait until fall for some drag strip hooligans. I hope to be faster.
what is KCLV?
what is KCLV?
