TPMS Mounting Solutions
Hi All,
Has anyone had luck with TPMS adapters/bracket? Have they come dislodged or have you run into issues with the PSI not being read ? I've been searching for a solution for my wheels and would like to go with solution 1 from my research. Just hoping to hear some feed back.
Will be mounting the adapters to BBS LMs
PIAA TPMS Vale Stem Mounting Bracket - CNC Aluminium https://www.upgrademotoring.com/whee...s_mounting.htm
WP626 26mm
WP640 40mm
WP659 59mm
Drill holes additional holes into wheels to accommodate TPMS - Leaning against this option.
Put all four TPMS in spare tire and call it a day
Build a sealed canister and fill to the required PSI - https://www.clublexus.com/forums/is-...pipe-bomb.html
WP626 26mm
WP640 40mm
WP659 59mm
Hi All,
WP626 26mm
WP640 40mm
WP659 59mm
WP626 26mm
WP640 40mm
WP659 59mm
http://www.workwheelsonline.com/tpms...apter-set.html
is300SD2 (08-21-18)
My understanding is that BBS LM valves are 8mm and Lexus TPMS are 11.3mm
