RCF Mufflers on ISF
You won’t have carb issues with any aftermarket cat back exhaust.
I was under the impression that cat back exhausts don’t change anything, regardless of how it looks. I doubt the techs know how many cats came on the car... can’t you even get carb certified exhausts systems?
but you will also also notice I said cat back... didn’t say which cat. Are you saying you can’t even do an axle back without failing, yet there are tons of FBO guys in California?
I appreciate your hyper aggressive response though. Cheers.
They do, they have photographs of the underside of the vehicles they inspect. As I said, if they do a visual, some don't, they will fail.
Sorry if I hurt your feelings, but you were giving advice on a subject that you really have no knowledge of. I lived in California for 25 years.
Lou
The more I learn about California, the happier I am not to live there.
It is really a question of, would you be able to line up the RCF muffler tips with the ISF bumper openings as I am sure you could fabricate if needed the hangers and modify the Y-pipe.
I just saw someone selling (in classifieds) an ISF OEM axle-back, stock Y-pipe with Magnaflow mufflers welded to it. Same Idea, it would just be with RCF mufflers right?
I don't think, it has been done before. It will start with measuring. RR Racing, PPE both make an exhaust upgrades for both cars, perhaps not a bad idea to reach out to them unless you could get an acces to both cars.
Lou
Lou
The techs, at least the one that did my smog check, have access to specifications of all vehicles except for grey market (like certain exotic imports), so they don't need to remember what model comes with how many cats. All they need to do is run the car VIN through the system, and the system will tell them how many cats there should be. What they DON't really check is if your cats are high flow or OEM since that requires a close-up inspection (like jacking the car up).
CA requires both visual and sniffer, and the visual includes inspection of the engine bay regarding your air intake box (non CARB aftermarket intakes are auto fail, whether in a box or not).
So yes, flowrider is correct on all accounts.
msgs350 (08-30-18)
good luck.
Tech Info Resource
When I lived in Sacramento, they were always quite thorough and always did full visuals and tailpipe testing. My Supra is now 25 years old and no longer has any smog testing required by Georgia. Best move I ever made.
