seized Front Caliper middle bolt/pin
Old 09-08-18 | 08:30 PM
Finboy's Avatar
Finboy
Default seized Front Caliper middle bolt/pin
No issues removing the upper and lower pad retaining pins and clip
But the middle pin/bolt with the 13mm inside bolt is frozen, seized.
(on both drivers and passengers side)
any suggestions or tips on how to remove that middle bolt/pin??
Old 09-08-18 | 11:22 PM
GaaraOTS's Avatar
GaaraOTS
hammer and soft punch
Old 09-09-18 | 06:44 AM
mrfurlly's Avatar
mrfurlly
Tiny bit of heat on those flanges may help get things moving if the above hammer/punch aren't sufficient.
Old 09-09-18 | 07:30 PM
FNSSESPORT's Avatar
FNSSESPORT
Leave the bolt that holds the middle bridge bolt in a few threads, and hammer on that bolt.
-R
Old 09-11-18 | 08:29 AM
MisterSkiz's Avatar
MisterSkiz
I had to use sandpaper and brake cleaner on mine, as it had caked on dirt and corrosion from all the street salt, and then I was able to punch it out.
Old 09-11-18 | 11:08 AM
Dtaylor3's Avatar
Dtaylor3
I had to hammer the ****** out of it. chipped some paint, but you can always repaint calipers.
Old 09-12-18 | 01:21 AM
lobuxracer's Avatar
lobuxracer
Tech Info Resource
-R
Get a longer bolt with the same thread that you don't care about and do this. A longer bolt will let you hammer with less chance of hitting the caliper and damaging the paint.
Old 09-23-18 | 07:35 PM
Finboy's Avatar
Finboy
M8x1.25 longer bolt and BFH No dice. Got mad and used grinder
Old 09-23-18 | 07:40 PM
Finboy's Avatar
Finboy
Second cut. Used BFH and inner came out. Used 1/4 punch and BFH to push the outer part out. (Man... it was in there good!!)
Old 09-23-18 | 07:41 PM
lobuxracer's Avatar
lobuxracer
Tech Info Resource
Damn. That's a really stuck bridge bolt. I've not yet had that problem.
Old 09-23-18 | 07:42 PM
mrfurlly's Avatar
mrfurlly
Wow, lol. That's one way to get it out. Did you try heat?
Try some anti seize on the new pins.
Old 09-23-18 | 07:44 PM
Finboy's Avatar
Finboy
New pin/13mm bolt on top * going to source that middle pin/bolt (Unless anyone knows a brembo or aftermarket part number)
Might try to source parts locally
Old 09-23-18 | 07:46 PM
mrfurlly's Avatar
mrfurlly
Is that paint on the middle section?
lobuxracer's Avatar
lobuxracer
Tech Info Resource
I just bought a small stash of them from Lexus so I could replace them at will if they ever gave me any grief. When you track your car, you get to know brake maintenance very well.
Old 09-23-18 | 07:49 PM
Finboy's Avatar
Finboy
Tomorrow Picking up a tube brush to clean out the bore for the middle pin. New one goes in tight.. too tight Might sand down the pin a smidge too.
