What a nice Accessory for my living room.(Subwoofer)
You're probably going to have clearance issues with putting the rear deck back on. I was in the middle of doing this also but I might just give up on it. I hope you find a way cause I cant think of anything unless raising up the rear deck some or grinding down the medal some.
Yeah it kinda does matter, therest definitely not enough room to mount the sub facing up, it has to face down like the oem oem style. Since you have attempted, notice how Lexus added slmesomet there to prevent putting aftermarket ones in, its llike they knew it was gonna break... I will not know for sure, ill let peolle know tmrw morning!
Fyi my mount depth is 2.8"
The OEM design has the coil part up top inverted, sub is supposed to face down try that.
I don't know either, im just trying to make a OEM bracket that everyone can use. Unfortunately, it may not be plug in play if I can't find that weird connector. I'll keep you all posted like I said
Being the way that I am I wouldn't be able to leave it like that. That would bother the crap out of me. Lol but all in all nixe job.
Only problem is, that the sub I have is dual 2 ohm so it wouldn't work with the factory amp. Was going to install it with a micro amp also but since it doesn't clear the deck I'm having second thoughts on it.
