Radio does not power on.
hey everyone today I was going to use my radio with the aux on my 09 ISF and there’s no volume, none of the fm/am, aux works or radio controls. I checked the fuses in the engine bay and under the passenger kick panel and there fine. So I’m stuck and have no clues what the problem is. Any thoughts?
There are a lot of threads about it. Mostly ppl saying their amp is out. Some have water damage, and amp shorts and turns off to avoid damage (if it rained take out the amp and dry it) but mostly it's the amp down.
if u mean that the buttons don't work? Than its the lower unit... more info?
If theres no volume most likely the MARK LEVINSON AMP. Its behind passenger side under trunk liner. I took mines off and tested my buddies amp from his F and that was the culprit.
3dolphin
10-23-17 07:13 PM
