Brake Pad Alternatives
For what it's worth, I have been using Autozone's Duralast Gold brand since March, already put about 20k on them when I replaced them along with Oem brembo rotors. Autox and drag strip days and daily driving, a bit less bite than OEM but brake dust is nearly nonexistent. I used to have to wipe down my black chrome wheels every day to keep them shiny, now I clean my current wheels maybe once every 2-3 weeks. Pretty happy with them for only $100.
2014acISF (07-04-20)
No clicking whatsoever. I like them a lot but just to be clear, it's not a pad you should track with. But for a daily they're perfect, no squeals, no dust, no noise, and while brake bite is less, it also makes it just a touch smoother to drive. Like I said, I've put just over 20k on mine since March. Also, I run them front and rear.
Just what im looking for. Im dont track. Just for daily driving.
Are you using the Duralast Gold rear pads as well? I was just checking their website and it shows the rear pads as being semi-metallic, so I would expect them to generate the same amount of dust as the OEM rear pads. I know the fronts do most of the braking, but I'd like to go with ceramic pads in the rear as well.
Hawk - Performance Ceramic Brake Pads - Rear (HB722Z.652)
You don't need ceramic rears from my personal experience, i wondered the same when i was researching pads. The regular metallic rears from autozone are good enough probably because the front pads use a bigger 6 piston caliper vs the 2 piston in the rear. I have the whole set from Autozone and the ceramic fronts dust similar to the metallic rears (duralast ones).
So duralast is not safe for aggressive driving? I’m seeing two different attitudes toward them? I like to know that I can stop faster than I accelerate on the quarter mile strip if needed. I also might road course it this next season twice.
I have done autox twice and a drag strip trip with 4 runs on the same pads, along with 20k+. On the later autox runs I could feel the brakes heating up and getting harder, probably because I wasn't going fast or long enough to cool them down. Ultimately I didn't have any issues, but if I were to go tracking with 25 minute+ sessions I would not trust them. I mean they're $100 and basically just for DD status which is great. Some people buy $600 pads just for the track/street and that's more than ideal. Some of those people don't put more than 5-10k on their cars per year though.
