Brake Pad Alternatives
#31
Yes thanks. I may race at Putnam this year which is six 20 minute sessions, so i will skip duralast and go a different route.
#32
So I installed the Pagid pads for the Mercedes on the front and I love them! Combined with the ceramic coating I put on the wheels, the dust is very manageable. Nice firm feel on the pedal, bite is great, noise is zero and I haven't noticed any fade on hard braking. I don't know if they are appropriate for the track but I'll figure that out next year at Limerock. Y'all can give it a shot and let me know what you think!
While I was at it, I painted the calipers cast aluminum with VHT and then used a 2k Urethane clearcoat over the VHT clear coat. A lot of coats of paint! If you're gonna do it yourself, be prepared to invest a lot of time in prep!! I didn't drive it for almost three weeks waiting for parts and supplies. Used high temp decals on the calipers after the paint. I didn't strip the paint; just cleaned and sanded them. Check out the pics below.
#33
Switched to Project Mu Hc800 and was amazed. Just don't be an idiot like me and not upgrade to a high temp brake fluid....had brake failure during a cool down lap at Putnam and was very lucky.
Changing pads is so easy...that's why I switch them out for track days.
#34
I want to resurrect this. I want low dust pads but want to keep the OEM bite. I drag race, and if my opponent looses control I want to be able to stop fast. I waited 6 months for special color Volks, and after a day you can’t even see the bronze in the gunmetal paint from the OEM pads. Duralast sounds like a good option, but I don’t want to lose any bite. Thoughts?
#35
Hopefully you drag at the strip but if thats the case go with project mu. I have the duralast and they bite great and are great for dd but for track or the strip id prob go with project mu to be on the safer side.
Jwconeil (04-20-19)
#36
I only race at the strip. What ProjectMu model do you recommend?
#37
Project mu ns400 were the go to pad for F's that wanted oem bite but no/low dust. But they were discontinued month ago....I was sad to hear this. I've been searching all year as after 4 years, I'm COMPLETELY fed up with the brake dust from the OEM pads. They stop great, but squeel here and there and the dust is unbearable....I might would get 25-60 miles tops of driving before the front wheels are covered.
Talked to Speedfreaks (a forum vender here) and he recommended Carbontech pads. Said they were basically the same as the ns400s. I got them (he even gave me a forum coupon code!), installed them and put them to the test immediately! On my 600+ mile trip from NC to FL, I didn't hear one squeel!! Checked the wheels and OMG!!!! ZERO DUST!!!!! I am truly baffled about that! Raced in the 1/2 mile event, with 15+ passes at 140+ mph and HARD braking from there and STILL zero dust!! No longer scared to drive the car before it sits in the garage for a week or 2 (can not let the car sit with dirty wheels in my shop/garage).
Highly recommend. Pricing wasn't bad at all either. Good luck!
V.
V.
Jwconeil (04-20-19)
#38
V.
V.
Vitveet (04-23-19)
#39
Keeping it Real
They may farm out some of their aftermarket rotor manufacturing (I'm not sure on that), but I'm quite sure Brembo actually manufactures their own OE-application rotors, including the IS F rotors.
Jeff
#40
Former Sponsor
Talked to Speedfreaks (a forum vender here) and he recommended Carbontech pads. Said they were basically the same as the ns400s. I got them (he even gave me a forum coupon code!), installed them and put them to the test immediately! On my 600+ mile trip from NC to FL, I didn't hear one squeel!! Checked the wheels and OMG!!!! ZERO DUST!!!!! I am truly baffled about that! Raced in the 1/2 mile event, with 15+ passes at 140+ mph and HARD braking from there and STILL zero dust!! No longer scared to drive the car before it sits in the garage for a week or 2 (can not let the car sit with dirty wheels in my shop/garage.
V.
V.
-Matt M.
Vitveet (04-23-19)
#41
Your #1 Lexus Vendor
We can do Project Mu or Stoptech brake pads guys!
Contact us for pricing!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#43
Project Mu NS 400 were the go-to pads for quite a while but unfortunately they were discontinued and replaced with the Type NS which is a slightly different formulation than the NS400. The Type NS compound still aims at ultra low dust and noise free operation but now with an increase in friction levels over the NS400 compound. Friction levels were successfully increased but unfortunately a bit more dust output over the old compound accompanied. Some people find that to be an acceptable tradeoff but for any of our customers who want the absolute lowest dust possible in a street performance pad we recommend the Carbotech 1521 compound. 1521 has slightly less friction than the Type NS, but as Vitveet mentions, essentially zero dust output.
-Matt M.
-Matt M.
k20trick
05-23-17 08:28 PM
cowsgomoo
04-25-12 01:17 PM
