Front Brake Rotor Replacement - Slotted
#33
We follow however the rotors comes OEM from the manufacture. Yes, drilled only isn't the best route to go with since these are prone to creating stress cracks but this is how Lexus wanted these rotors so this is how we offer the rotors. It is possible for us to get these in just the blanks from our manufacture and I would have to request this from my product manager. However, we would need to order at least 100 pieces to make it happen. If you guys want these in just the blanks where we can machine these in slotted only, let me know and I'll put in a request in. I would need serious inquires for this too.
#35
I have a set of Brakenetic GT slotted rotors F & R. I really like them!!! No track days with it but I have done multiple runs on mountain roads. No issues as of yet especially down hill. I used to run the old OEM drilled rotors but after some hard runs in the hills, the drilled holes began to clog causing vibration and eventually start to crack. Really wanted to do the 2 piece rotor but the price was a bit much. Also, when comparing OEM vs these rotors I've noticed the fronts have the center hub cut "deeper" to expose more of the vents for more cooling. Time will tell if these rotor hold up.
#36
Tech Info Resource
Mountain runs don't equal track duty. Nothing you can do on the street approaches what track use does to rotors.
#38
So I went ahead a pulled the trigger on a set of Brakentic slotted rotors and did an initial review on them below. Hope this helps!
https://www.youtube.com/edit?o=U&video_id=mfAuex0lD74
#39
3nergiz3d (01-06-19)
#42
