Sunroof not working with selector switch
So to be clear the sunroof will fully open, close, and tilt. Only problem is that it will only do open when I turn the **** fully counter clockwise and hold it and it will only close with **** in the closed position and pushing the **** down. When closing I have to feather it until it's flush with the roof line or it will just go in to tilt position so I have to fine tune it.
Is there a recalibration procedure like with the windows (fully down and hold, fully open and hold)???
I'm in Washington and it's getting cold and going to start raining soon, but this is bugging me.
Thanks for any help and direction.
Edit: I've searched the forums and "googled it".
Tech Info Resource
chelms166 (11-22-18)
Thanks for the reply. I saw that post too. I ended up just googling and finally found an IS250 with the same issue and found the recalibration step. Just hold down the button for 30 seconds and let it cycle through it's full travel. Works just fine now.
Seems my google tactics were a little out of cal and needed a refresh. Hopefully this will be useful to someone in the future. Cheers.
Tech Info Resource
Sorry, I thought I referenced this post:
https://www.clublexus.com/forums/is-...l#post10330136
This has the factory procedure in it.
chelms166 (09-07-19)
