Intuitive Parking Assist Front Sensor.
I figure more people have the parking assist on their ISF than the other 2IS crowd.
For those people who have parking assist on their car, how close do you have to get to an object before the front sensors go off? I felt like I got pretty close to the car when I turned out of a parallel parking space. I purposely turned close to the car to see if the sensor would go off like the rears do (ie slow beeps first, followed by more constant beeps as I get closer) when I'm reversing, but it doesn't. I know the sensors work because when my girlfriend walked by them when the car was in neutral, the sensor just made a solid beep.
Does the front only work only in certain gear positions? Is there a way to adjust the sensors to have more sensitivity in the front? I know on the nav you can adjust the rear, but nothing for the front.
Let me know your experience with your sensors.
What I actually really wanted to know is your real world experience with the front sensors since this is new to me.
So when the car is in neutral and people walk by, the warning sensor will pop up on the navi saying there is an object near by. When the car is in drive, and I get close to another car or object, definitely within 1.5ft and a half, it doesn't beep/warn me at all, even if i'm going less than 6 mph. Is this normal?
Definitely doesn't beep when I parallel park or when I turn into a parking space slow. I'm wondering if that's just how it was designed. I read threads where people with RC-F complain about how the front corner sensors don't really do anything.
Anyone else have the sensors. Let me know your experience
There isn't one at the 12' o clock position, but there are two front corner sensors. I'm guessing from your experience the front corner ones are useless?
Edit: Just checked and it seems like I confused the radar cruise control with the parking sensor
The ones on the front side (10 and 2 o' clock) work fine. If I recall correctly, there are 3 sensitivity settings for the parking sensors. I forget where it is at... might be to the left of the steering wheel as an actual button or in the menu settings on the nav screen but I recall it showing up in the top left of the speedometer where it shows temperature, gears, etc. in the 2012+ speedometer. I set mine to be more sensitive (detects items further away at an earlier rate) to give me a margin for error. Sounds like yours may be less sensitive.
. Looks like the only sensitivity setting is for the rear sensors.
DROG2002
10-18-18 06:22 AM
