IS-F gets louder as oil mileage gets longer
I've noticed this, now even non car people have commented that about my car. Anyone else notice this? Currently at 7200 miles on the mobile 1 syn. Maybe Im crazy and its just an exhaust leak?
Tech Info Resource
No, I have not had this experience.
I change my oil annually or at 5,000 miles, so can't offer opinion
Yeah I’d never let a car go over 5k, so can’t relate. If that’s really the issue, change your oil sooner.
Tech Info Resource
I've gone 12k on a change. Fully documented with used oil analysis in the Blackstone thread and photo evidence in the valve lash thread. Never an issue regardless of mileage.
Tech Info Resource
Mobil 1 5w-30 or Mobil 1 0w-30. I never have needed to add oil even on the extended changes. Sounds like your rings didn't get fully broken in if you're burning that much oil.
I found the 0w-30 makes a whole lot less of the weird ticking noise on start up than 5w-30 does.
Oil will be sent out for analysis.
My first oil analysis is on its way to BlackStone with Eneos FS 5w30. ill post what they find here
Jwconeil (07-21-19)
Tech Info Resource
No, and I think it's a bad idea to believe the engineers designing the oil package failed to get it right so it needs some kind of additive. If you're really concerned about it, run either Amsoil Signature Series 5w-30 or Renewable Lubricants PCMO 5w-30. There are no better oils with or without additives available.
