RR Racing Stage II ISF E85 kit makes 652whp! Thats around 770hp
Well that's not bad considering the numbers they pulled out of it...........at least there is no more guess work on the capacity of the stock tranny. I'm assuming rebuilding this transmission would be expensive to boot!!
Is that the engines limit as well? I wonder how long the engine / trans will last at this level.
Yes sir now we now know I always wonder what or stock trans would hold. On pump gas 582 which is not bad at all. E70 tune puts it damn near 800hp and 652 whp to give some perspective how much that is compared to some other cars McLaren 720's are putting down anywhere between 680whp and 690whp depending on dynos, Hellcats around 670whp, Demon on normal mode 707hp, new ZR1 654whp. Well done RR Racing.
MileHIFcar (01-02-19)
IMO I think they could squeeze some more out of engine it all depends on how much money a person would be willingly to spend? If you want to have a completely built motor I'm pretty sure they could do it. But its trans that now becomes the Achilles heel and how much would that cost to get built$$$$$
I want to learn more about their big supercharger kit in the works. We know an engine build is 10+ K. Lord knows what a tranny build is, and a larger supercharger kit will cost more than the current one. It would cost serious money to make more than the 652 they currently are.
Why spend time and money developing more hp/tq when transmission can't hold much more power. Not until transmission issue has been resolved would it be worth spending time and money on more hp.
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
We are working on making more power, only because we want to continue to push the platform forward. That said, if you ask me, I think the current levels of E85 tunes that push between 620-650whp are really the sweet spot in terms of reliability and use of the car. With our current levels of SC tunes, the car is reduculously fast at the track, stupid fast on the street, and an absolute blast to drive.
Rafi
The following 7 users liked this post by RRRacing:
breed (08-11-19),
Defratos (01-03-19),
ImportISF (01-03-19),
ISF5L (01-02-19),
MileHIFcar (01-03-19),
and 2 others liked this post.
Rafi
Rafi
I’d be happy with a 600 whp tune that will last. I’d rather be conservative if it’ll make things safer. After I have a garage to work within the next year, I may contact you about a custom full E85 setup with a more conservative tune. I don’t like mixing fuel.
Sponsor
So you think 620-650 whp will be reliable long term? Is that over spinning the blower?
Rafi
Rafi
