Taillight wiring diagram - wire colours
Old 01-11-19, 03:47 AM
jwgorrie
jwgorrie's Avatar
Default Taillight wiring diagram - wire colours
Hey, anyone have a chance to work out or a diagram that shows what color each wire is for the tail lights on the IS F?
Much appreciated,
John
Old 01-11-19, 08:17 AM
Arein
Arein's Avatar
Didn't looked into the pdf but hope it's useful
File Type: pdf
Old 01-11-19, 11:35 AM
Vervish
Vervish's Avatar
Not a wiring diagram - but Spec D taillight install instructions might also help..
http://site.specdtuning.com/installa...2004012015.pdf
Old 01-11-19, 06:08 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,958 Likes on 2,397 Posts
What spec is it? UK, Aussie, or Japan? Not all are the same.
Old 01-12-19, 08:01 AM
jwgorrie
jwgorrie's Avatar
UK spec, bought a multimeter and hopefully I’ll be able to work out what’s what.
If anyone has a definitive colour guide I’d be most appreciative of getting hold of it.
ill have a look at the attached diagram, thanks for all your help everyone.
Old 01-12-19, 08:52 AM
jwgorrie
jwgorrie's Avatar
Just to give some Context to this request I have purchased the VLAND tail lights and was wondering if there’s anyway to tap the inner boot running lights to the outer brake light so when the lights are all off, the inner ones light when the brakes are used?
Old 01-20-19, 09:41 AM
jwgorrie
jwgorrie's Avatar
Got there in the end...
Hey everyone, after some thinking I’ve managed to wire the light up using a normally open relay that when triggered by the brake light 12v, it closes the relay and sends 12v to the inner tail lights.
So now when I brake with the lights off (daytime) both the outer and inner running lights activate!
Such fun, and makes them similar looking to the other non vland lights, in that you get the L pattern when braking right across during the daytime when your lights are usually off.
If anyone needs the colours let me know! Although it may be different by country model???
Best bet is use volt meter!
bbudenos
08-18-17 02:41 PM
SLVRGS3
10-12-10 06:14 AM
bobinsofla
Lighting
12-23-08 08:59 AM
Staticam
08-17-07 07:46 PM
kissbang
09-28-06 01:24 PM
Quick Reply: Taillight wiring diagram - wire colours
