Oil on pistons
I’m the third owner. The maintenance done on the car was just oil changes and a spark plug change at Lexus. I know me to but who knows I also found some battle scars underneath the car like if one of the previous owners climbed over a side walk or something. I also have a deep dent and cut in my oil pan but nothing on my subframe. Weird stuff but who cares I fixed everything already.
Tech Info Resource
Sounds like one of the previous owners lowered it and didn't do it right. Glad you fixed it all up. I'm planning to buy all solid bushings shortly to eliminate all the rubber compliance in the suspension, but it would be horrible if the bushings were already trashed. That's a whole lot of parts to replace, good on you for doing it right!
Tech Info Resource
Will you please post the procedure for setting / loading the bushings for us noobs?
Tech Info Resource
