VLand headlights - projector LED
Old 01-29-19, 09:03 PM
21ce
21ce's Avatar
Originally Posted by Wh0pp3r
Dont you just pull a fuse under the dash to turn light off no longer the procedure.?
Yeah but doesn't it also stop the vertical leveling motor? Yes, i understand that can be adjusted manually.
Old 01-30-19, 05:19 AM
PatrickISF
PatrickISF's Avatar
It wouldn't matter if you are using the VLand headlights since they use manual adjustments for the LED lights. If you are using the OEM projectors, then it would disable the leveling motor, yes.
Old 01-30-19, 06:21 AM
FFM
FFM's Avatar
When it comes to lighting, if there’s no upgrade to output then it seems like it’s not an upgrade at all.
Guess I could understand it if you didn’t have the factory LED strip lights, but from what I’ve seen so far they don’t appear to be any better output, which is kind of sad. Our factory projector is mediocre at best.
Even with the spendy D4S CBI’s and clear lens upgrade they don’t compare to many of the basic projectors on the market.
Old 01-30-19, 11:29 AM
McPierson
McPierson's Avatar
I was under the impression there was a leveling motor on the VLand Lights...
Old 02-01-19, 10:55 PM
kartoos100
kartoos100's Avatar
I am planning on getting this for my ISF. Any one with an SFP ISF who have bought these headlights? Would like to have a look before placing the order. they are closed till the 25th of Feb so I have time till then.
Old 02-22-19, 07:33 PM
kartoos100
kartoos100's Avatar
I just picked up these bad boys from China. The packing is top notch and the product looks well made. I will take it back next week and will install it soon after. Will put up some pics soon after. I also got the blacked out tail lights.
Old 02-24-19, 07:09 PM
JPxMODz
JPxMODz's Avatar
Old 02-24-19, 08:11 PM
MileHIFcar
MileHIFcar's Avatar
Wow! those don't look half bad
Old 02-24-19, 08:31 PM
JohnMorgan
JohnMorgan's Avatar
I've seen them in person and I really don't want to like them but, the build quality is top notch and they do look really good. Considering a nice set of HID bulbs or OEM goes for $120+ per bulb, at $550 for these it makes decent sense. Especially if you have a pre facelift car, these should be considered.
Old 02-24-19, 08:35 PM
mahcah
mahcah's Avatar
Contradicting statement in a way there. You just might like them later then lol.
Old 02-24-19, 08:37 PM
JohnMorgan
JohnMorgan's Avatar
Originally Posted by mahcah
Contradicting statement there.
I should clarify. I don't want to like them because I'm not a fan of trying to make a last-gen car look like the new models (i.e. F10 M5 bumpers on E60, 3IS Bumpers on 2IS etc etc.) BUT, these are executed very well.
Old 02-25-19, 05:22 PM
FWizard
FWizard's Avatar
Originally Posted by JPxMODz
Very curious to see this on your car since you have the same colour as I, Silver Metallic. Wondering if you need the eyebrows to fill that black void on top.
Old 04-14-19, 12:26 AM
BlackISFNY
BlackISFNY's Avatar
What color temperature for this checkmarks and low beam? 5000k? or 6000k? Hint of blue?
Old 04-14-19, 12:04 PM
FMYLIFE
FMYLIFE's Avatar
So is there a definitive answer as to whether the light output is better or worse than the stock ISF HIDs?
Old 04-14-19, 08:34 PM
MileHIFcar
MileHIFcar's Avatar
I'd like to know as well about light output........seems like we've gotten subjective answers so far..... I'm more concerned with the highbeam output as I utilize the highbeams on dark roads quite often....would be nice to get lumen output to compare
Quick Reply: VLand headlights - projector LED
