Headlight Problems
Headlight Problems
I’m sure there’s a post in here somewhere about it but I’m having a hard time finding it. My headlight had a leak and filled with water ruining the ballast and his bulb, I opened it sealed it all replaced the ballast and the light worked for a bit, then randomly isn’t working at all. I was told xenondepot could help. Anyone who knows where i could find info on this please let me know!
What side headlamp? You said you changed the ballast, did you also change the bulb or did you use the old bulb? I had the same issue on my passenger side headlamp about a month ago, but I ended up just replacing the headlamps.
