Lexus F-Sport Underbody Chassis Brace on IS-F
ChpEng (03-29-21)
JT2MA71 (03-31-21)
#48
Looks like this F-sport brace hangs 1.0-1.5in lower than the factory beams.
Is it higher, lower, or about even with the body side sills?
Trying to get a feel for how much ground clearance is being given up.
Any problems with rubbing or rattling against the factory exhaust resonator?
Any comments would be much appreciated.
Thanks.
Thanks.
ChpEng (03-29-21)
#50
I am still at stock ride height and have not experienced any issues (at least not that I have heard/felt). The "X" part does sit quite low but it is close to the rear wheels. I will check for scrapes when my F comes out of storage.
ChpEng (04-13-21)
#51
ChpEng (04-13-21)
#52
Did this mod on my 2012 IS-F - with special brackets
Thanks to this thread, I did this mod on my 2012 IS-F which has a stock exhaust. It was pretty straightforward. I made two small brackets to tie down the loose tabs on the exhaust head shield. I am on stock suspension with 245-40-19 front, 275-35-19 rear. Ground clearance seems to be OK. Only additional change was to use pan head socket head bolts for the two brackets where they attach to the brace, to give a little more ground clearance
#53
Wanted to confirm if the three brackets / braces shown in the photo below, are also installed on the 06 - 2013 IS 350? Also, is the part referenced by the yellow arrow in photo, the "tunnel brace"?
#54
Have since confirmed two of the three braces are also installed in the 06 - 2013 IS 350 as well. I assume all three shown braces in photo were also installed in the 06 - 2013 IS 350.
DrivenSoul
Suspension and Brakes
23
01-31-14 10:48 AM
emikelee
08-20-10 12:51 PM
