So today I had a bird hit into and got wedged in my lower grille. The grille is cracked and will be replaced but I noticed there is a lose connector behind the grille. Can anyone help as to what this connector/sensor is and where it should be located? Many thanks
I believe thats the outside air temp sensor. should mount somewhere on the inside of the front bumper. the sensor appears to still be intact but the "slip socket" it mounts with looks broken. you can just zip tie it up.
Thank you all for the comments, much appreciated. ISF from the UK but with 2012 alloys sourced from here, PPE dual exhaust and upgraded 2012 cream seats.
