Cracked Radiator 2008 IS-F
So i knew this was going to happen, but I didn't expect it today lol. Today was the coldest day we have had in a few weeks, 49*. I turned the heat on max and usually within 2 minutes i have some sort of heat coming out of the vents. NOPE, not today. and when the car was up to temp, if i went a little faster than normal, the temp gauge would drop down. I pulled into a local grocery store parking lot and opened the hood thinking maybe I had the valley leak and the coolant was low. NOPE, I saw coolant sprayed all over the front of the engine etc. then looked at the radiator to see the top tank bubbling out and leaking where the metal fins clip on. SO i filled the overflow with distilled water and the heat started working again with about a half gallon. drove 5 minutes home and parked her. I did smell coolant yesterday on the way home from work but i thought it was the car in front of me.
Car has just around 135k
Today after work I ordered the below to get done in a couple of weeks:
Coolant splashed everywhere
I'm not sure if you can see all the coolant bubbling under the hose inlet.
- Koyo Aluminum 48mm radiator part # HH012170
- I will be bypassing the transmission heat exchanger lines
- OEM water pump (had a small leak)
- OEM thermostat
- OEM serp belt tensioner
- Already have a replacement belt
- Already have 2 gallons of SSL coolant
I have the koyo radiator and you’ll never have to change it out ever again since it’s all aluminum. It also holds more coolant then the oem one.
Any definite way to check whether your headers are cracked without going underneath the car?
