Gt500 rotors on lexus is f brakes
Old 03-17-19 | 03:38 PM
OneFastF's Avatar
OneFastF
Default Gt500 rotors on lexus is f brakes
Wanted to know if anyone has ever attempted this? This was out of curiosity since many doing projects cars usually use Jeep OEM Brembos on project cars because it was way cheaper. After checking the rotor sizes the IS F brakes were bigger by .2" than the GT500 brakes. (Front). What do you guys think?
Old 03-17-19 | 04:13 PM
Jwconeil's Avatar
Jwconeil
To what end? Save money? Are the GT500 rotors cheaper? You can get OEM ISF rotors on eBay for like 7 nickels.
Old 03-17-19 | 04:24 PM
OneFastF's Avatar
OneFastF
Two Piece Rotors for a GT500 is $800 compared to $1,200 on an IS F. Wanted to see if I can do it. #cheapo
GT500 2-PC - MFG from Girdo Disc
Old 03-17-19 | 07:01 PM
ISFpowered's Avatar
ISFpowered
What two piece rotors for the ISF are you talking about that cost $1200?
Old 03-18-19 | 11:32 AM
Jwconeil's Avatar
Jwconeil
The idea of trying to mod an ISF on the cheap is bizarre to me. These cars are very expensive to mod. Might as well do it right.
I could build a track ready fiesta ST, with the cost of the car, for the amount of money that has been invested in my car. If budget is an issue, an ISF is not the car you want to build. Not bragging, I didn’t buy most of those parts. Just giving perspective.
a big turbo kit for a civic type R is about 6k from full race, and they are top end turbo kits. A top end coilover for this car is 4K easily.
Old 03-18-19 | 11:38 AM
OneFastF's Avatar
OneFastF
This is out of curiosity... Besides I already have a new Diff (LSD) being installed on my IS F and already planning to get some RR Racing stuff after. Example, Obviously I can blow my cash on a $2,000-3,000 exhaust if wanted, but is it worth it? Not for me. Just looking for more cost effective options... Nothing wrong with saving money for other things.
On that note, I'll like to stick to the topic I asked.
Old 03-18-19 | 12:47 PM
Jwconeil's Avatar
Jwconeil
Ok. I’ll bite.
I think Gt500 rotors fit ford GT500s. ISF rotors fit ISFs. This is probably the only response anybody here can give you. You may take that as sarcastic, but it’s factual.
Old 03-18-19 | 02:48 PM
FNSSESPORT's Avatar
FNSSESPORT
You’d probably get brake pad wear that was 0.2” from the edge of the pad?
FYI - the RR Racing 2-piece front rotors are on for $900.
-R
Old 03-18-19 | 02:50 PM
OneFastF's Avatar
OneFastF
-R
Yeah GT500 rotors run a bit smaller. Thanks for the suggestion also!
Old 03-20-19 | 11:04 AM
SpeedFreaksUSA's Avatar
SpeedFreaksUSA
Former Sponsor
I haven't confirmed but the GT500 rotors also likely have a different offset than the IS-F rotors and almost certainly have a different (smaller) hat diameter since they use a D1001 pad shape which is a taller annulus compared to the D1365 the IS-F uses up front (55mm for the D1365 vs. 59.35mm for the D1001) on a smaller diameter rotor. Interesting idea but likely not at all worth the effort to make it work. FWIW we are working with Stoptech to come up with a direct replacement 2-piece AeroRotor that is targeting ~$800-900/pair sale price.
-Matt M.
Old 03-20-19 | 11:10 AM
OneFastF's Avatar
OneFastF
-Matt M.
Thank you Matt!!! This is the answer Iooking for!!. I'll take a look.
Old 03-20-19 | 08:29 PM
Jwconeil's Avatar
Jwconeil
-Matt M.
Any idea what the weight savings will be?
JC07ES350
ES - 5th Gen (2007-2012)
12
05-04-22 05:21 PM
Scott610
07-20-15 09:21 AM
melbitoast
03-29-12 05:46 PM
TMaxxTim
Suspension and Brakes
12-14-05 01:45 PM
alexus
05-21-04 09:05 PM
