Brake Replacement Recommendation
3rd Gear
So I finally got my hands on a 2013 IS F. Had dealer take a look at it and it's good to go. Front brake pads are 4mm and rotors are 28.5mm. Dealer is pushing replacement of pads and rotors. I believe rotors are okay until 28mm. Any thoughts on the pads? How many miles of average city driving do I have left?
Start by reading this thread:
https://www.clublexus.com/forums/is-...struction.html
Should answer your questions.
Lou
Lou
The pads standard thickness is 9.8mm, with a minimum thickness of 1mm... You have some time left on the pads maybe 25% left, how
many miles that is for you is hard to say. The rotor standard thickness is 30mm, minimum is 28mm. Whenever you decide to do the pads
you should replace the rotors.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/a8aee067_ea4c_455f_a472_08a4a107106e_3aee53670d925366f22fae411bd8e13a8e271356.jpeg)
Get some RR racing two piece rotors F+R and some Winmax 4 pads and your going to love the bite! If that’s to much for your liking just slap some duralast pads on.
Cheap project Mu pads here: https://www.jdmyard.com/catalogsearch/result/?q=USE20
It takes time to ship from Japan, but with the conversion rate it's dirt cheap!
^^^^You most likely did. See Post #40 here:
https://www.clublexus.com/forums/is-...natives-3.html
Lou
Lou
I would honestly stick to stock rotors, they can be had for dirt cheap instead of the two-piece aftermarket, unless all you're going after is the bragging rights or you have noticed that stock rotors are not good enough for you, and stay clear from ProjectMU's, we've had some not-so-good experience with them, especially if you intend to put your car to track use. The ProjectMU's honestly only lasted me 1 track day, from brand new pads to no pads in 1 day and when I took them out, they basically fell apart, whereas my friend had them fail on the straight @ Summit Point coming into T1, he went off-site and hit the wall in his ISF and what looked like easy 50% of the pad left, just disappeared. (Based on Mike it probably has to do with too much heat in them, accelerating their demise)
I usually do 5-8 track days per season, mixed with some TT and I've now been tracking ISF for 5 years, pretty much settled on stock rotors, which I replace probably once a year and a mix of Carbotech's XP10's in the back and XP12's in front, so far's been working well for me, but if you're just going to daily it, XP8's should be a nice compound for the DD.
I would never replace with stock rotors. The holes are prone to cracking, especially on the track. A slotted rotor is a much better choice.
Lou
Lou
Lou
Do you know of anyone that had cross-drilled rotors and they failed? I've heard this about cracking can potentially be dangerous, but only when cracks start to connect with others, now if you track the car, do you not check your brakes like a hawk? I do, but I was honestly dumbfounded by how quickly HC+800 disintegrated, I've gone through different brands and compounds, this was by far the scariest one, while I also expect my pads to last between 2-3 track days, depending on the track.
^^^^The HC+800 is a dual purpose pad. If you are that tough on track days, IMHO, it would be wise if you had 2 sets of pads. Street or dual purpose pads for the street and dedicated track pads for the track. BTW, I run HC+800 pads on the rear and Ferodo DS2500 on the front. I don't do track days, but do drive aggressively. I have one piece slotted rotors on the front and am very happy with my brake systems performance.
Lou
Lou
