Front Bumper Cover Alignment
I had to remove the front bumper cover to replace the signal lights, and after removed and installed the bumper back, there are gaps at the fender/under the headlight. There are instruction on how to remove it but the most pita is putting it back and align it correctly. Does anyone know if there is a procedure on the front bumper installation like which side to mount first or which bottom bolt should fasten first before the others ? I find it's a design flaw that the front bumper to remove to change out the bulbs.
I think it's aligned under the headlight, but the fender/headlight gap is more obvious than before the removal. Also, there are 2 bolts under the driver side that I was unable to fasten them because it's not aligned with the under body panel. I'll try to post some pictures.
Prinny
01-23-17 11:42 AM
