"Wheel of Fortune" rattle when decelerating\coasting from ~35mph
#91
How is the NVH on the street version versus the race version, and did you compare them to the Kein mount in your testing? I was oddly thinking of this again as I look to track time next year. The oem mounts just aren’t up to abuse.
Have you seen any signs of subframe wear/cracking with your engine mounts?
No issues with subframe wear. I would say the Black, street version is more than enough. The harder you go (RR Red or Kein) it just gets worse. I believe Rafi has the Black mount on his car and reported some NVH. That said, I've logged about 8 total hours behind the wheel of his car to date and I don't find it bad at all. There's a little road feel through the wheel at low speeds. The car is loud and I don't hear any extra noise because of that.
-Justin
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#92
Thank you @lobuxracer for mentioning this sound in another thread as it lead me to find this larger thread on the subject. I have this same sound right now and have ordered all the parts to replace it. Thanks everyone for all the part numbers in here.
#94
New transmission mount resolved most of the noise
i have the same noise in my 350 , the faster i go the more it speeds up
https://youtube.com/shorts/l71dVklv8uk?feature=share
Will replacing all the bushings in the transmission mount be sufficient?
So I finally replaced the transmission mount and the noise is 90% gone. The mechanic didn't jack up the transmission while replacing the mount and the brace that connects with it, is that a reason its not 100% gone?
Should I be worried? the old mount was about the same height as the new OEM one.
Thank you
#95
**UPDATE**
Thank you
Thank you
The bracket (shown below referenced by Yellow arrows), is only used with the IS F V8. not IS with V6.
#96
I was under the car working on installing the driveshaft so I replaced the tranny mount (OEM) and the bushing at the front of the linkage. The mount wasn’t compressed as other reported but felt little bit hardened.
As far as the bushing, it wasn’t deteriorated yet, but very hard and dry so good decision to tackle it. Thank you for the part list.
It is just one nut to be removed and then it gets easy. It comes down for a great access. If you ever under the car, easy task.
#97
Hello Rossi,
Were the following parts installed for the transmission control rod shown in the photo below;
9040 - 17013 - Grommet for transmission control rod (referenced as 35569C in parts diagram)
90560-08091 - Bushing for transmission control rod (refrenced as 35569G in parts diagram)
33726-35010 - Connecting rod Pin W/HOLE for transmission control rod (refrenced as 33675A in parts diagram)
90468-14011 - Locking Cotter Pin for transmission control rod
Parts Diagram
Parts Diagram
#100
#101
Thank you again for the follow up!
Browsed the discussion to better understand where the linkage located, to perform the parts change as well (IS350). I understand this to be discussion for IS F vehicles however, interested in knowing if the the link assembly would be located in similarb location underneath the IS350 as with the IS F?
Photo 1- front link assembly? (provided by Joe Z Reply # 62)Joe Z – Reply # 62 - I swapped the grommet & bushing today, putting the F back on the 2 front jack stands.. It was a tight space to work in, but got some lessons learned.. Have the right tools and make sure the car is safely high enough.. Working on a lift would have made this swap much easier..
Photo 2 - shows rear link assembly circled in Red (provided by ISFpowered Reply #66)
Part 3370230610 - (2008 IS F / 2022 IS 350 LUXURY) - AUTO TRANSMISSION ROD SUB-ASSEMBLY, GEAR SHIFT LINKAGE ROD LINK NO.1
Part 3370230580 – (2008 IS350) AUTO TRANSMISSION ROD SUB-ASSEMBLY, GEAR SHIFT LINKAGE ROD LINK NO.1
PHOTO 1
PHOTO 2
PHOTO 1
PHOTO 2
