Little help gentlemen
So was driving my 2011 isf today went to make a full throttle pass on highway.. tranny dropped down then bam no power. Traction control light came on and check engine light started blinking...pulled over turned car off cussed it out a few minutes, restarted car no lights but ran fine....just did plugs the other day but been fine till today...any and all help would be great...sold my e90 m3 cuz was starting to worry about things happening since it just hit 110k but now im having buyers and sellers remorse..whats first thing i should check...im not the best at fixing cars, just driving them
Well last time i shut it off i restarted it and no check engine light... decided to take her out again and hammer it a few times and sure as shi* happened again, now checkengine and traction light stayed on...of course i loaned out computer thingy...im guessing and hoping speed sensors...i did just do all 4 rotors and pads and had to do some serious hammering to get rotors off. Maybe knocked something loose
Tech Info Resource
vertex16 (07-03-19)
Tech Info Resource
This nails it on the head...
Doing pads and rotors is actually ridiculously easy on the ISF. People think since they are Brembo(or Lexus, since it says Lexus) believe they are complicated pieces to deal with and should be left to 'professionals'. That is BS, the calipers are the easiest type to work on and were practically designed for ease of swapping pads. Men have been working on their own car brakes since the beginning of the automobile, I believe we should all continue this trend. All that is involved for the pads is removing two pins, a spring clip, and a 13mm bolt. For the rotors; two 17mm bolts hold the entire caliper in place, remove those and set the caliper down on a jackstand or hanger, and your now at the rotors...if the rotors are stuck, there are screw holes on the rotor, use two bolts[size M8x1.25] to pop the rotors off. You can get those bolts at most auto stores or Home Depot.
DIY ISF Rotors and Brakes - YouTube
Well i certainly wasnt the one doing the brake job...defenitly not happy that my guy, who beat up the rotors instead of taking them off properly. Prob last time he touches my car.
Pulled the codes they were all random misfire codes...erased the codes and traction light went off as well...hopefuly just got bad gas....should i get octane booster or fuel injection cleaner along with new gas? All suggestions good or bad are appreciated
Tech Info Resource
If better fuel doesn't fix this, I would check for oil leakage down the sparkplug tubes. The seal between the valve cover and the head sometimes leaks a little and it could cause something like this. I once had a bad misfire problem that was simply a dirt track down the side of the sparkplug conducting when it shouldn't have.
So only at full load does it misfire...idles smooth drives smooth until i full throttle it...so im gonna get all new coils am i stupid to buy the cheaper ones on amazon or do i gotta spend like 60-90 a piece on the denso coils...i appreciate the help fellas
Would a leaking typhoon intske cause misfires?? Cuz the intake is loud but the quiet then loud again but im not sure if its cuz its misfiring its doing that
