I seem to be having a hard brake pedal when I depress it prior to turning the car on. Sometimes I have to press the brake pedal and start button more than once to get the car started. Is it possible that the master cylinder needs to be replaced?
Had the same issue. I replaced the check valve and grommet 1st but it didn't fix it. Ended up being a leak in the brake booster. Had it replaced under warranty.
