Isf overheat on track
Hi, i just came from my first session of lapping today, (in the isf), i won't tell you it wasn't a hot day but my car overheated after only 3-4 hotlap, it's a 1minute max lap, first session i got out after 10 minutes , 2nd i manage the 15 minutes by not pushing the car too much on the straight, 3rd same thing it overheat after 5-6 minutes , i know it was hot but i figured that it was the car that should not overheat and made to be pushed, and car got slower when too hot , i had the oil at 6 bars and water temp touching the red, as soon as i lift off a little the temp would go down in a minute, car is healty , no leak, no check, 70kmiles, i'm thinking radiator and condenser fins too much beat up by time that would decrease flow trough, anyway, it was a blast, i learned about the car today, first , them brakes are INSANE , i was braking from 200kmh to about 60 in 200meters non stop, never fade , ridiculous, handling was nice but bumpy, like on the road lol (2008),my only issue here is that overheat , i was loosing a lot of power i guess it's from the pcm , if any of you got ideas i'm listening, tanx .
I track a decent amount and water temp has never been an issue (needle never moves from the middle). However, it is common to get to 6 bars on oil temps - happened to me all the time until I bought the RR oil cooler. I would start with figuring out the water temp issue first (radiator, thermostat, water pump, etc.) - that for sure is not normal. Good luck....
The following 2 users liked this post by lexicon72:
lobuxracer (08-01-19),
v8sedan (07-27-19)
Never had the water temp rise on me at the track, only the oil temperature. You could have a clogged up AC condenser that is not allowing enough air to flow through to the radiator.
I looked at the rad condenser assembly i could easily see the flashlight on the other side , i dunno, maybe i'll start with a thermostat not to start throwing parts around like crazy 🤔
Venting the hood will help massively with water/trans temps. Stock hoods leave the air no where to go. Venting will increase efficiency of the elements over 100%, add a oil cooler and you'll be good.
v8sedan (07-29-19)
Looked for a leak on waterpump even if i changed it , no leak, looked for the valley plate leak and didn't noticed nothing (that i can see), lower condenser is a little beatup at the bottom grill from rocks i guess , but top part looks new, fans works, but cannot see if they kick in high speed because i was not able to duplicate the spirit driving on the street lol. I'm stuck between bringing it in or trying a new thermostat and see, or trade in 😂
RJMacReady (06-26-24)
If you don't have any leaks... maybe the thermostat isn't opening?
v8sedan (08-01-19)
