Widest Tires in Stock Wheels and Height
What's the widest tire run on stock wheels and height without rubbing?
I purchased an 2010 ISF with 08-09 wheels and it came with 235/35/19F and 275/30/19R which makes it around 25.5 diameter.
Stock is 26. I'm assuming that 255/35/19F and 285/30/19R will run into rubbing issues which is why the prior owner likely went with 235/275 or that he didn't want to squeeze them on 8/9 inch width wheels.
Anyone running 255/285 on stock 2012+ wheels without rubbing on stock height (without pulling fenders, running negative camber, etc).
I have a 14 that Im currently running 245/275. It so much better than stock. There is a guy on youtube with a white one that raced every car at the track. His set up is 255/285 and no problem. I dont think it makes any different though.
On my 11" I am running 255/35/19 front and 275/35/19 rear with stock height without any issues or rubbing. I will be upgrading to coil overs early next year so, those specs may rub. We shall see...
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
There are several other threads that touch on this topic, but the general consensus is:
- for 2011 and older models you can run up to 255 / 275 on stock wheels (some have ran 285s with mixed reviews; 275 is "max" for 9" rim)
- for 2012 and newer models you can run up to 255 / 285 on stock wheels
I have 255 / 285 Michelin PSS on my 2013 at stock height and have never rubbed.
I spent a considerable amount of time researching this topic since the roads are pretty slick where I live and lack of traction has been an issue for me.
NotFSport (10-14-19)
Im running 245/35, 275/30 on stock 2011 wheels, lowered on front Swifts. Very slight rubbing in reverse on fender liner. Fixed it by cutting off a small piece
I tried 285/30/19 on the rears but felt too floaty. Went back to 275
running S-04's F:255/35 & R:285/30 on stock 08 rims. stock ride height on stock suspension. no rubbing
