Suspension opinions
#46
I'm eager to hear your feedback as me personally, didn't get a big improvement in ride.
08 Isf
Currently looking for a solution and ohlins may be it.
Roads here are bumpy
#48
A lot of things come into play as far as how comfortable an isf feels. 2011-2012 model years are the softest. 2013 went back to being a bit stiffer. As discussed, tires play a big role as well. Not only tire side wall but brand. Some brands have much stiffer side walls than others.
I also believe that something in the alignment of the isf plays a role in how comfortable it feels. After I installed my ohlins my car was very comfortable. When I installed my second set of headers, I went for an alignment as well and my car became super stiff and jarring. I had to get a header adjustment because they were hitting the subframe. This time I didn't get an alignment and my car was back to being comfortable.
Can you post a link of the ones that ohlins sells direct? The ones that figs sells are valved specifically for the isf. I couldn't find anything direct from ohlins website for the isf.
#49
This is purely my opinion based off of what I've experienced first-hand, but anything I've ever personally installed a set of KWs on has always been very nice to drive, both on and off the track, whether a customer car (at work), or my own. I own 4 other cars with KWs on them (1 with V1s, 2 with V3s and 1 with Clubsports), most of which did not start off on KWs, some of which have previously used the other mentioned brands. With the exception of the Clubsports, all of the KWs feel pretty close to factory in terms of ride quality (in some cases, even better), and are absolutely something you can drive around with on a daily basis while also offering excellent performance out on the road course.
I find that setup means a lot when it comes to coilovers, regardless of how much the kit costs. A set of what one would call "entry-level" coilovers that have been setup properly will offer a much nicer ride quality and better performance over a kit that costed much more, but was setup poorly. That being said, none of the aforementioned brands are entry-level, and are all fantastic. The quality is definitely there with all 3 brands, the only way you can really go wrong is on the setup end of things. Many things play into the ride quality that you get out of any coilover setup (spring type, spring rate, ride height & shock travel, spring preload-if applicable, valving/dampening and rebound adjustments-again, if applicable).
If you're looking for every last millisecond on the road course, assuming the "driver-mod" isn't an issue, I'd say the Ohlins track coils might be your best bet, but for a car that sees mixed road and track use or if you compete in amateur racing (time attack, etc), the KW V3s are no slouch for what they cost.
My F currently sits on a set of BC BRs with standard option springs which were installed by the vehicle's previous owner. After adjusting them properly (proper preload, height, etc), the ride really isn't bad for what the kit is worth and I'm sure you could easily get by with these on the street and occasional track day, although I do feel like they lack refinement. All things considered, I'll still be replacing the BCs with a set of KWs in the very near future as I know there's more to be had suspension-wise.
Whichever kit you decide to go with, just remember that the foremost important part is that the coilovers are setup properly by someone competent, with the car at a reasonable ride height. The setup WILL make or break any kit you buy.
#50
Tech Info Resource
The other thing we're missing in this thread is, subjective ride quality assessments are as individual as the person driving the car. Street ride quality can be satisfactory across a broad range of solutions. If you want to win races, all that changes very quickly and you have to measure actual performance with a timed course and as consistent a driver as you can find. It's a completely different world and none of the suggestions for suspension I've seen in this thread would be adequate. So you have to decide what you ultimately want before you can even consider brands. If you are NOT racing, you can run just about anything and it might be OK for your application. If you ARE racing, then there are few choices - very few.
#51
Guess it's that time
I lent my ISF to a friend due to a temporary hardship of him not having a car and me having my Prius now as DD. Welp...
Guess it's time for some suspension. Seeing as it's only a weekend car now debating on what to get. Figured bilsteins and some springs just to make the ride a bit less harsh seeing as mine is an 09.
Thoughts and Ideas?...this car isnt getting track time anytime soon unfortunately. Also going to get new rubber all around in bigger size than what it came with, figure it might help as well with the ride comfort.
Something went wrong here...
#52
#53
I’d explore the 2014 Dynamic Sport Tune Suspension.Thats the last of the model made pretty sure that’ll have something that your after without to much of the compromise of trying a boat load of settings you’ll have to find using after market coil over and spring setup.
Or as an option find out the above settings ie spring and compression rates of thee above and get a shock valved and spring to suit thee above numbers.
#54
Tech Info Resource
#55
I put Swift springs on the front only of my 2008 two months ago, quickly got tired of how rough the ride was on top of the already rough 2008 suspension and removed them. I upgraded to KWs and they are night and day. Still stiff, anything for this car will be, it'll never be like a Camry or whatever, but the bump absorption is way, WAY better.
Here's the staggered, front lowering springs only / stock rear look that you asked about though.
#56
I'm guessing it also works with the other ISxxx, but not sure what makes the Figs one so much more in cost.
#57
Its this one: https://www.ohlins.com/product/road-...05-2013-use20/
#58
The ones for the isf should be spec differently from the is 250/350 because of the weight difference. Also when you actually try to buy the model (LES MI00) that you posted, it shows that they're for is 250/350 only. The ones that figs sell are specifically valved for the isf and also come with helper springs.
#59
I was thinking the same, but i just had the oil serviced maybe 2500 miles ago prior to this and i didnt see any odd wear on the tires. figured maybe the bushing filed while my friend was driving it and he just didnt notice the driving difference or noise.
he did finally tell me that he did notice front end vibration at 60+ while on throttle that he didnt "think anything about it"... with that being said, im just gonna bite the bullet and do the shocks all around and LCA rear bushings. gonna be fun.
#60
Tech Info Resource
The OEM bushings like a little toe-in if you want to manage tire wear. Once you put a stiffer rear LCA bushing in the front you can get away with a little toe-out and the car will turn in better. It won't trail brake as well though. I'll take consistent over squishy any day.
Springs and shocks won't hurt anything, but if the dampers are not leaking and the springs aren't sagging unevenly, they're not the root cause of this wear issue. You'd see cupping if there were a problem there.
Quick refresher in this thread:
https://www.clublexus.com/forums/is-...alignment.html
