'08 ISF Oil Replacement 5W30 vs 5W50
I'd take a look at this blog:
https://540ratblog.wordpress.com/201...-test-ranking/
There are lots of "performance" builders who mistakenly believe higher viscosity oils are better. They're not. Nobody in F1 is running 50 weight oil....there's a good reason for this.
I wouldn't recommend changing anything since you're well down the path with this, but I would run from anyone recommending heavy oils and building to accommodate them. They're thinking 1950's technology.
Steve
