ISF and GSF oem intakes interchangeable ???
The following 2 users liked this post by flowrider:
lobuxracer (01-14-21),
Rickna (07-14-21)
Joe,
Does the RC/GS-F pipe/maf panel of the intake assembly fit the ISF box?
I have the RR tuned intake, I like the idea of the bigger MAF pipe diameter. However there are some things I personally would like to change, and if the rc/gs panel fits i think it might achieve both my goals
IIRC you said the diameter of the gs/rc pipe is closer to 3.5", and the RR maf housing is 87mm (3.43")
1. I prefer the induction noise of the stock intake system.
2. I believe the aluminum housing of the RR tuned intake system causes some excess heat soak for me in the summer months here in Texas. Moving to an abs plastic certainly cant hurt.
Tech Info Resource
No, it does not. I have both in the garage and the GS F needed an air filter change, so I tried putting the GS F piece on the IS F and it failed. There are small differences between the two units making it impossible to connect them.
Tech Info Resource
Tech Info Resource
Pretty unlikely. The heads are different castings.
