Low charging Alternator.
Hi all,
I need advice about my charging system. I have 2012 F with 62K miles. I measured my battery is about 12.5VDC. When I turn on my car at idle, it's reading 13.3VDC. Is it too low for the F? I could not start the car this morning. I have to have a jump. I also have a dashcam direct connect to 12V supply. Do you think the Alternator is bad? or the Dash cam draw juice out of the battery overnight? Thank you for all advices.
Ericspyder
Ericspyder
Tech Info Resource
Take a look at this thread:
https://www.clublexus.com/forums/is-...sues-swap.html
It sounds to me that 13.3V at idle is normal.
I was in the exact same spot a couple months ago. I thought my parking cam drained the battery and put a lot of stress on the alternator, but turns out I just needed to recharge the battery overnight with a trickle charger.
I disconnect my parking cam last night, it was fine this morning. Thanks for the advice.
