Squeak sound after PPE Headers install
Just recently got my PPE Headers installed. After a few days I started hearing this squeaking sound every time I drive over bumps/dips and imperfections in the road. It also happens sometimes right as I come to a complete stop. It sounds like it’s coming from underneath the front of the car where the headers are. The car still drives completely fine.
Any idea what would be causing this?
How many miles are on your car, and does it have the Original oem engine mounts?
Might be those mounts. Most ppl get those changed out when replacing headers.
Just recently got my PPE Headers installed. After a few days I started hearing this squeaking sound every time I drive over bumps/dips and imperfections in the road. It also happens sometimes right as I come to a complete stop. It sounds like it’s coming from underneath the front of the car where the headers are, and I also hear it sometimes (not often) coming from the rear when I go over a speed bump. The car still drives completely fine.
Any idea what would be causing this? Could the subframe bolts be a little loose?
Is it this kind of squeaking?
https://www.clublexus.com/forums/is-...ion-noise.html
Or does it sound more of rubbing? If it sounds more like rubbing, it could be the brackets from underneath the car.
See post #34.
https://www.clublexus.com/forums/is-...staller-3.html
I've had some noise coming out ever since I got my PPE headers installed.
See post #34.
See post #34.
Tech Info Resource
But there is no need to separate these unless you are installing a new mount. I didn't separate them at all when I did my starter. I did remove the air filter box to get a little room and I removed the bolts holding the steering rack to make it easy to slide it out as a unit from the front on the passenger's side. Not sure how easy/hard that might be on the driver's side as I didn't replace the mount at that time.
