AC issue DTC code 24
I'm getting DTC Code 24 on my AC system and wanted to check the AC Magnetic Clutch Relay, but I can't find it. Any suggestions?
Thanks
Thanks
Tech Info Resource
There isn't one. There is no clutch on the A/C.
DTC 24 is for the solar sensor. If you were in the dark when you checked your DTCs, you'll normally see this. I see it on Techstream all the time while in my garage.
Originally Posted by Factory Service Manual
If the check is performed in a dark place, DTC B1421/21 or B1424/24 (solar sensor circuit abnormal) may be output.
JLB1010
Performance & Maintenance
10-10-23 02:14 PM
