Compiled Coilover Information
#136
I actually was speaking with Figs for a bit, the 16 springs were backordered a few weeks when I was ordering and I figured I would try the 18/14 set up. I was originally going with 16/12 on BC BR but upgrade to DS because of the stiffer spring. Depending if you prefer stiff or soft,,, 20/16 sounds pretty stiff o.o
Does anyone here have a pair of swift springs16k (or close for BC coils) that they're looking to get rid of?
#137
Thanks! I've emailed Figs to get some guidance and really appreciate the feedback here and I misunderstood your response. I thought you wanted the ISF to be stiffer, but sounds like you were referring to your IS350.
msgs350 (03-04-23)
#140
I'm on BC BR + Swift 14/12 on my IS350 at 100k~ miles with no issues
My IS F is on BC DS + Swift 18/14 and rides smoother (dampening) at near stiffest setting than my IS350. 15clicks (about half) softness was super cush and comfortable but I prefer it to be stiffer.
Both cars are set about 2 finger gap all around.
Very happy with both, mostly just street and spirited corners with occasional canyons
#141
#142
They ride softer and more comfortable than the BR and other ISF/RCF/GSF owners have ridden/drove my car and like them too, The BRs are generally pretty smooth but can get harsh, bouncy at times, the DS seem to be more soft/smooth bouncy. I'm about 10 clicks from the top. I tried 15 clicks from the top and it basically was really smooth and not bouncy but since I do like to the hit the corners I stiffened up the clicks a bit. Might try to go even stiffer this weekend as last weekend I hit the canyons and my street/cruising setting was a bit softer than I liked.
Not sure if it helps but some vid of the canyon "bounce" for reference
The following 2 users liked this post by bakalag:
CCColtsicehockey (07-10-23),
evltwn (07-10-23)
#144
I hope you enjoy them! I was really impressed with mine, I was expecting a harsher ride with the stiffer springs but it was way more compliant than I expected.
evltwn (07-10-23)
