View Poll Results: Tip options
Rectangular 5.5 x 3 rolled tips.
10.00%
slant cut duals 3.5 single wall and 7.5" total across.
10.00%
3.5 single wall.
10.00%
Somehow turn the OEM tips into actual exits.
70.00%
Voters: 10. You may not vote on this poll
Aftermarket exhaust tips! Poll.
Old 09-20-20 | 11:57 PM
av8or's Avatar
av8or
Originally Posted by LSpho
The Hayward and Scott ovals still look suitable but they look a little off compared to the OE.
i have the Hayward and Scott and the tips provided are of a smaller oval shape. I stuck with the OEM tips.
Old 09-24-20 | 08:08 PM
LSpho's Avatar
LSpho
Does anyone have or can anyone photoshop ISF with 4 turn down muffler / turn down tips??? I'm thinking the turn downs in the same orientation as the / \ cut outs or turned away would look nuts. Maybe I envision the idea of it better than the visual. Also might go with spintech 8000 dual in dual out instead of a borla or magna
Old 09-25-20 | 06:29 AM
Jwconeil's Avatar
Jwconeil
I am not against the idea of single exits but not for me personally. JW, are your singles slant/slash cut?
Sorry - I thought I replied to this. Yes, they are slanted and fit the profile of the bumper.
This is the best pic from the side that I have. I can get better shots if anyone is interested. One fair warning, now that I have true tips, I can see that my right exhaust pipe is not perfectly symmetrical to my left. I am not gonna mess with it until my lift is installed. It’s off by maybe a 1/4 to 1/3 inch, but it drives me nuts. Gives my car a bit of a wandering eye effect.
Old 09-25-20 | 09:38 AM
LSpho's Avatar
LSpho
Looks good going at a similar angle as the form of the bumper, decided to go for the dual slant cuts to get that same desired effect. I feel the same way with the exhaust tips and the wandering eye effect.
Old 10-31-20 | 10:14 AM
LSpho's Avatar
LSpho
Update: has pictures! The angle cuts individually or as a Y’d dual unit will not fit properly at all. It’ll fit at really odd angle causing the axle back section to require weird looping pipes. Cutting and dremeling around the exhaust cut out will have been required as well.
Due to complications had the shop go with the classic straight cut single wall 3.5 staggered quad exhaust. Had no stainless on hand so just went with the mild steel the exhaust shop had.
Muffler delete bazooka tips on xforce exhaust, oem catted headers, xforce resonators in place. This is way too loud at all times except highway which has a soothing minimal bumpy drone and at high rpm. I’m considering putting a 4x10.5x20 spintech muffler in place of the resonators to reduce noise.
*** can anyone confirm if that size OR bigger can fit in the centers where the xforce resonators are? Maybe removing the heatshield ( left piece left of hotdogs in picture ) is possible is said by the exhaust shop? ***
May add better pictures and perhaps videos at a later time.
Looks good to me, maybe the rust specs in winter will add to that “ raw “ look
terryvly
IS F (2008-2014)
85
08-28-21 07:21 AM
Ajowhan
Performance
11-01-18 11:48 AM
Emackny
12-29-08 11:31 AM
jonathancl
09-15-05 11:26 PM
