Installed Antigravity Li Ion battery today
#77
Hey fellow F owners,
For the benefit of other buyers, I thought I would post a review to show another option as well as installation of group 48 on here as it is the perfect size (I believe ISF has the same battery size). The size is pretty much identical to OEM Panasonic the car came with. Only polarity is reversed, but it can easily be installed.
I installed everything myself. Other than releasing the two plastic cable clamps, rest of it took 10 minutes. It is a perfect fit height, width wise. I chose the 30 Ah battery because it offered great weight savings with enough cranking and Amp-hours since I don't use accessories much.
The polarity is reversed, but it is easy to install. The only challenging part was taking the two harness cable enclosures out of the plastic clamps that hold it to the battery plastic cage. Once those two clamps were open and the cables could be freed, rest was super easy. Just need a 10 mm small wrench that could fit in the tight spaces.
So the weight reduction is 27.2 lbs I weighed the OEM Panasonic battery this RCF came with and it was nearly 40 lbs. The Antigravity 30 Ah battery weighed in at 12.8 lbs so a total of 27.2 lbs weight reduction. The car cranks insanely fast as if there is no weight/centrifugal force in the spinning moments. Although, I noticed the cold start was a bit "tamer". It did not sound as ferocious, but maybe it is in my head. Anyway, it drives fine and seems like a great and very high quality product.
Picture of the Antigravity AG-H6-RS battery at 12.8 lbs
The most difficult part. Put a flathead screwdriver and twist and the tab pops out
The battery finally installed with reverse polarity. Only thing is, you cannot put the cables back in the plastic clamps, but it is alright. Looks great
The two key fobs the battery arrived with for the jumpstart techology. I did not get the battery healthy monitor like many of the guys on this thread, but I did not order directly from Antigravity, but a third party US vendor.
#79
Overall, the first impressions are great. Decent weight reduction, great cranking power, restart capability with the FOBs, theoretically lasts 8 - 10 years
#80
Tech Info Resource
I have not noticed this at all. The good thing about LiFePo4 is when it gets cold, all you need to do is keep trying. Unlike lead/acid, it warms itself internally and works better with a load. Some Antigravity owners turn on the headlights for 20 seconds or so when it's cold to get the cranking amps up. I have started mine down to 20F and not seen a noticeable difference in starting speed. I don't live in an ultra cold place and have no intentions of ever doing so. Grew up there, not going back.
ChpEng (02-28-21)
#81
Maybe, I will make a video of it. It starts in an "explosive" manner and then the car goes quieter as the rpm drop to around 1000 rpm after that considering the engine is still cold. Before, it used to hold the rpms for a bit before dropping back.
At least, quieter than before when the for about 1 minute, the car would hold high rpm before it would drop.
p.s. my garage is climate controlled at around 75 F or 24 - 25 C so temperature is not an issue.
#82
Tech Info Resource
BTW, the IS F and the RC F do not use the same battery. The RC F uses H6. The IS F and GS F use Group 24. Antigravity makes a perfect fit battery with the terminals in the right place for the IS F and GS F. I have one in my IS F.
The following 2 users liked this post by lobuxracer:
05RollaXRS (02-28-21),
Joe Z (03-03-21)
#83
OK thanks. I thought ISF also took OEM group 48 as well as like the RCF. Good to know it is group 24. The group 48 has the perfect size from what I could see for the RCF. Just opposite polarity, but I made it work, which is why I thought I would share my experience with ISF guys.
BTW, this thread is great as I found it very informative about AG from here and probably would have went OEM, if I had not read it so I really appreciated it.
p.s. Thanks for the tip regarding headlights. My car's headlights are set to 'auto' so I will test out the cold start like you said by switching to manual since they always come on automatically in my parking garage
lobuxracer (02-28-21)
#85
Any knowledge as to why the RCF went to a group 48? I have a battery in my daily showing some age. I may give it my Costco ISF battery and pick up one of these for the F, along with a trickle for the long winters.
#86
Tech Info Resource
Only Lexus knows for sure. Seems very werd considering the RC F and GS F share a whole lot of sheet metal in the front.
#87
Received 1,064 Likes
The major difference is the recessed posts found on the 48 / H6
Both are spec'd with posts towards the firewall..
There has has to be a reason why IS F / GS F use 24 and RC F use 48 or H6
Joe Z
#88
I'd get the Group 51. It's lighter, smaller, cheaper and has plenty of kick to start and run the car. The AG battery I have now is less than 10 pounds as measured on my scale, rated at 24 Ah, and spins the engine over better than any lead/acid battery I've owned (I've had three of them in my IS F!?!). I like the 10 year warranty assuming I won't need to use it. That's what sucked about the red top in my Supra. When I drove it daily, I never had a problem and they lasted about 6 years. When it became my occasional driver, they lasted about 24 months, I got a replacement, it lasted 24 months, then I had to buy a new one because the replacement doesn't have the same warranty as a new one. Hated it. I'm looking forward to a sub 10 pound battery capable of holding its charge for long periods of sitting. Just what the Supra needs.
Since it doesn’t have the kick start, can these be jumped like a normal battery with jumpers?
#89
Does the battery have low voltage protection? (Turning off if voltage gets too low)
#90
The exact discussion point was "some of the older cars don't shut off all the computers and can be a problem. Newer cars are pretty good about this." So, my takeaway was parasitic losses while shut down. I let my car sit for a week while I was visiting my dad in Iowa. Temperatures were from the 20's to the 50's and I disconnected everything to do the valley plate (and originally intended to replace all the cam drive as well) after sitting 3 days. On day 6, I started up from cold, and I saw the voltage go up one bar from normal, which tells me the battery was charging where normally I never see this with daily driving. I'm pretty convinced this battery is more than adequate for my use case on my '08. If you're really worried about it, the 30Ah option would provide more reserve, and certainly there are other options with even more capacity, but I think those would be total overkill.
I plan to buy another battery just like the one I have for my Supra when it's time to replace the one I have.
